deck light dims without system, might need cap?
Old Mar 1, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i have a 6.5" component set and 6x9s in the rear running off a 50x4 pioneer deck. when i listen to music that puts out lower bassy notes and when the bass hits from the speakers, the lighting on the deck dims little. i do plan to put a sub and amp in my ride eventually, so i ask: would this be a sign to invest into a cap since my deck light dims even without my system? its noticeable if you pay attention to it, but no other lights dim when the bassy notes hit off the car speakers.
anyone else have this small problem?
Old Mar 1, 2005
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
no big deal, just run the constant power lead directly to the battery, and run the ground to the chassis of the car. Problem solved.
Old Mar 1, 2005
Bires's Avatar
Bires is an unknown quantity at this point
To clarify, the constant power (yellow) lead of the head unit directly to the battery, instead of the one in your radio wiring harness.
It's strange though that your deck needs more power than your factory power lead can provide.
Old Mar 1, 2005
zachgeyer's Avatar
thats nutz
Old Mar 2, 2005
MassMayhem's Avatar
If you dig deep into the bowels of the installation instructions, they mention it in passing. Most high power MOSFET head units will be happier going right to the battery.
Old Mar 2, 2005
runner1738's Avatar
has anyone had problems with it not going out all the way? there have been times recently where i come back to my car and its hard to start cause hte battery has been draining all night cause the dome light doesnt turn off all the way, so i have to either keep it off or make sure that i always switch it off before i head out
Old Mar 2, 2005
Bires's Avatar
Nope. Check your door switches.
tylerginevan
Apr 27, 2015 12:29 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
NeoMagus
Nov 17, 2001 07:29 AM
