intallation help...
Old Feb 25, 2005
  #31
gatorsactions's Avatar
gatorsactions is an unknown quantity at this point
Cool
Originally Posted by PopcornPlaya
Yes, crimping works fine. I preefr solder myself because I have a solder gun, adn I trust it more than crimp connectors, just a matter of personal preference. If you choose the butt connectors, I might recommend the ones with the heat shrink tubing on them, so once you crimp, you can warm it with something (lighter works fine, I use my heat gun) and shrink it around the wire. As far as if you solder onto the speaker terminals, no, buy solder on male and female spade connectors (if you're soldering). If you're not soldering, you want crimp on spade connectors (female). The positive terminal is the larger size spade connector, and the negative side is the smaller size spade connector.
Are these the type of connectors you're referring to when you talk about the criimp style with the shrink tubing? http://www.cardomain.com/item/STISGLINK
So I'm getting components and 6x9s... lets see I need 12 of these correct? And that will allow me to make my connections... Sorry I'm just a beginner
Old Feb 25, 2005
  #32
Mystic3030's Avatar
Yup, i'm an A$$hole.
Dont bother with those...go to a car parts store, you can get virtually the same thing alot cheaper...I bought a pack of 200 butt connectors for $6.
The spade terminals are a slight bit more expensive, but you can get around 25 sets of them (male and female) for about $5, instead of the cardomain price of $2.95 for 1 sets
Old Feb 25, 2005
  #33
sweet. thanx mystic.
umm.... what is a "butt connector"?
Old Feb 26, 2005
  #34
Bires's Avatar
Bires is an unknown quantity at this point
little plastic tube with a metal tube inside. They are about 3/16" wide and 1" long.
wires go into each end.
Old Feb 26, 2005
  #35
Mystic3030's Avatar
THose are butt connectors
mrohitredd
Apr 15, 2015 08:13 PM
CivicMexicano
Apr 24, 2003 10:51 AM
thaicivic
Oct 30, 2002 10:39 PM
ehj3000
Sep 3, 2002 01:15 PM
