HU blinks on hard bumps
Old Feb 7, 2005
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
WTF is going on? I hit a hard bump and the HU lighting dies but the unit keeps playing...no XM interruption, no nothing, just a lack of lighting momentarily. Any ideas? I have to go in for an oil change tomorrow and I also have time in my day to go see my installer. BTW, the deck is a Premier Pioneer DEH-P8MP. Thanks all.
Old Feb 7, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Originally Posted by NoLeadEmSoMuch
...Any ideas"...
Sure. You have a short.
Maybe in:
the head unit itself (most likely)
the orange dimmer wire on your head unit's harness (unlikely)
Old Feb 8, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
is it a detachable face. Maybe the face bounces enough so it doesnt make a good connection
Old Feb 8, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
loose connection or short. This isn't a tough problem.
Solution 1. Just check your wiring and all your connection for a start.
Soultion 2. Don't hit bumps
Old Feb 8, 2005
MegaHurtz's Avatar
My guess is poor connection somewhere... make sure the face is firmly pressed into the deck. I had 2 similar problems, one where my face wasn't clicked in properly and I would use a control on the right side of my deck and my deck would shut off. The other was just recently when I went over a bump it would quickly cut out then come back on, and I found out that was because the plug going into the factory harness wasn't secure (eventually came out altogether actually) and it was losing contact for that brief moment when I hit the bump.
Old Feb 10, 2005
xwarp's Avatar
xwarp is an unknown quantity at this point
i have a deh-2300 that would lose illuminattion and control, but would still stay on. the lady i bought the car from stated that the deck had been returned to best buy for the same issue. it's still under warranty, but to go with out a radio for two weeks just to have the problem return as it did from the first time it was sent in wasn't worth it. well, especially since i am an electronics tech anyway. turns out there were a couple of cold solder joints around the power connector on the mainboard. reflowed the solder with silver solder and viola, she's fixed. after seeing several post regarding the same symptoms, i can only attribute the failure to contamination on the main pcb during the solder bath.
what happened to quality control?
bill
Old Feb 10, 2005
slicksivik's Avatar
my cd skips when i hit a huge bump. but no problems after that. what can i do besides not hit a bump. haha
Old Feb 10, 2005
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Yeah sounds like a loose connection. Just take the HU out and mess with the wires and see what one you mess with causes the loss. Then secure it better and bingo problem solved.
Dawit Melese
Oct 4, 2015 08:02 PM
MamaBear2015
27
Sep 22, 2015 04:04 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
First Car
Sep 8, 2015 08:54 PM
thaler4cuse
Sep 7, 2015 08:25 PM
