Alpine CDA Head unit owners - help
Old Feb 5, 2005
mattnyc's Avatar
mattnyc is an unknown quantity at this point
I have the alpine cda-9831 and it was installed by bestbuy.
After the head unit has been on for a while, i hear a buzzing noise from the headunit, not the speakers. It happens regardless of a cd being in the unit or not. Anyone else hear this. it is a very low sound.
Old Feb 5, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Sounds like maybe the motor for tiliting it. Is something obstructing its motorized path?
Old Feb 5, 2005
tripledoublegs's Avatar
Euro-Spec
I'm not sure if the alpine 9831 has a cooling fan. I know my 9833 has it and it sounds kind of annoying. Anyways, if you got that extended warranty from best buy they should fix it no matter what.
Old Feb 5, 2005
mattnyc's Avatar
i think it may be a cooling fan issue myself. i installed it at bestbuy but bought it on ebay. the sound is not always there, only after its been on a while and i have been pumping my music. Hopefully after a dedicated 4 channel amp, the headunit stops buzzing.
Old Feb 5, 2005
MegaHurtz's Avatar
most likely a cooling fan
Old Feb 6, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Probably a fan, but my fan never kicks on since I use amps and shut off the internal amp on the HU.
Old Feb 6, 2005
mattnyc's Avatar
I didnt know you could do that. I will make sure they do when i get my 4 channel amp.
Old Feb 6, 2005
Mystic3030's Avatar
I dont know if the 31 can do it...I have a 9835. I would assume you can though. Look for an option to turn off the "PWR INT" or something along those lines...it'll be in your manual too.
4 banger
Jun 5, 2015 01:44 AM
rawtalent14
Jan 22, 2002 09:29 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
