sub/amp problem
Old Jan 27, 2005
alexcorvice's Avatar
alexcorvice is an unknown quantity at this point
sub/amp problem
runnin' a MTX 251 roadthunder amp wit a 12 inch Eclipse Subwoofer
2003 sedan LX
anyways so when I turn on car amp power light goes on and as soon as I turn on my deck panasonic cq 8300u no power to amp and no boom boom from ma sub. This just started a couple of days ago besides that has been working just fine since the original install. Any ideas would be much appreciated.
Old Jan 27, 2005
catalin's Avatar
catalin is an unknown quantity at this point
You installed this yourself???? Do you know if the remote wire was connected properly?? The remote wire is a blue with a white stripe. If it's connected properly then it's either a problem with the amp or the deck.
If you have a test light or a multi-meter you can easily check the remote wire at the amp to see if it has 12V positive when you turn the deck on..... OR it could always be the fuse at the battery.
Check those things and let us know.
Old Jan 27, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Could be RCA cables unplugged or Speaker wire too. Also, the amp might be in protection mode.
Old Jan 27, 2005
I got the whole system deck amp sub and speakers done professional. Just called the install place. apparently there is an issue with the panasonic cqc 8300u and just random electrical issues occuring. So gonna have to replace and try different which really burns my *** cuz Panasonic is the only one I know that makes a deck in gun metal.
So new question anyone know of another brand of deck made in gunmetal?
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
