Help getting the Back seat out plz!
Old Jan 9, 2005
Jeff B's Avatar
Jeff B has a little shameless behaviour in the past
Question Help getting the Back seat out plz!
I currently am working on getting my system all setup in my 01' Coupe. I have all of the wiring in place and the system is all hooked up and working. I took out the back deck and the side panals in the back. I mounted the amp on the back of the fold down seat use a 1/2" thick piece of plywood. Now I need to figure out a way to run the wiring to the amp so that you cant see any of it. How do you get bottom part of the back seat out? And I also dont know how to get the back seat cover reconnected? I am getting a digital camara soon and I will post of pictures.
Old Jan 9, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
there's a bolt and some retainer clips that hold the bottom part in...the bolt is right near the middle (a little closer to the left side if my memory serves me correctly...) ...just stick your fingers in the crack between the back and bottom parts of the back seat to find it...use a 10mm socket and a ratchet with an extension to remove it...it's a completely unnecessary bolt, so i wouldn't even bother putting it back in if i were you...after the bolt is removed, just pull up on the seat to remove it...
as for reconnecting the seat cover...it's kinda hard to describe...i'll try to draw something up in Paint or something real quick...so hang tight, i'll BRB...
Old Jan 9, 2005
Jeff B's Avatar
awsome. Everytime I would pull on the seat it felt there was something holding it down I just could'nt find it.
Old Jan 9, 2005
alright, here's the best i got...the pics show the seats as if they are folded down...i'll try to give you the descriptions first...
in the first pic, that's the seat and the flap that covers the foam, etc...in the "magnified" area, you can see that at the edge of that flap is a thin strip of plastic (inside the cloth) that is kinda "hinged"...
in the second pic, you'll see in the "magnified" area that on the seat there is a groove-like piece that runs the width of the seat...take that little flap described in pic 1 and fold it under and put in the little groove as shown in pic 2...then just zipper your seat up if it's not already zippered...
that's how my 'Vic's seats are, anyway...hope this helps...good luck!
Old Jan 9, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
It's a piece of black plastic, it's a fold under retainer. Just roll it out holding between your thumb and forefinger.
Old Jan 9, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
ive got the crutchfield master sheet that shows how to take it out. if you want it pm me and i can email it to you.
Old Jan 9, 2005
"fold under retainer"...good call...that's what i meant to say ...thanks!
Old Jan 9, 2005
Jeff B's Avatar
ok sounds good. It's prob gonna be hard to get together because I have a 1/2" thick piece of wood under there but I got the idea.
Old Jan 9, 2005
Jeff B's Avatar
I was able to get the bottom part of the seat out. I never would have found that hidden 10mm bolt, thanks man. I am gonna get up tomarrow and continue working on it and hopefully get it all done by tomarrow. It's lookin great so far though...
I will take some pictures of it soon and post them. The great thing about this setup is that all of the wires are hidden. If you want to take the box out, all of have to do is disconnect the speaker wire.
Old Jan 9, 2005
good job, man...props for doing it yourself...need anything else, just post up again...good luck!
mistermenphis22
Apr 3, 2016 08:06 AM
jordan1794
Jun 8, 2015 04:03 AM
Blazz
May 25, 2015 10:56 PM
Myredjonda
Apr 14, 2015 07:00 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
