rpm cluster arm?
Old Dec 26, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
rpm cluster arm?
is it normal to have the rpm arm close to the one, and not at 0. i noticed that when you look at both the speedometer/rpm arm, the speedometer arm is at 0... and the rpm arm is near the 1. my warranty is ending soon, and i'm not sure if i should address this.
Old Dec 26, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
are you looking when yer car its running?
Old Dec 26, 2004
rckdrmr's Avatar
when i turn on the engine, it goes to the 1. when then engine is not turned on, it stays near the 0.
Old Dec 26, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
Of course it's normal, your engine is idling! When the arm goes to 0, your engine has stalled.
I believe 700rpm is the "normal" idle for our cars. You will find that it will idle much higher when you start it on a cold day. It hasn't gone above 20 degrees here in a week and my car is idling at about 1,500rpm from a cold start. Once it warms up it will idle at 700 again like it's supposed to.
Do not be alarmed.
Old Dec 26, 2004
rckdrmr's Avatar
Do not be alarmed.
Old Dec 26, 2004
diskreet's Avatar
Did you ever take time to learn how an engine works and what rpm's really mean? honestly howstuffworks.com has some great articles on cars.
Here are some good learning tools:
How engines work:
http://auto.howstuffworks.com/engine.htm
How manual transmissions work:
http://auto.howstuffworks.com/transmission.htm
How auto transmissions work:
http://auto.howstuffworks.com/automa...ansmission.htm
How steering works:
http://auto.howstuffworks.com/steering.htm
How horsepower works (what horsepower really means):
http://auto.howstuffworks.com/horsepower.htm
How mufflers work:
http://auto.howstuffworks.com/muffler.htm
And something not for us, how rotary engines work (Like in the Mazda RX-8's, Rx-7's, etc.):
http://auto.howstuffworks.com/rotary-engine.htm
Old Dec 28, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
my car sits between 800-1000 rpm in idle, nothing to be worried about
Old Dec 28, 2004
SiG's Avatar
SiG
if your tach was at 0 when you're at a stop, then id worry bro
Old Dec 28, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Except if your driving a civic hybrid. Then you can comfortably enjoy the silence
fatih717171
Jul 25, 2016 06:22 PM
7thgensurvivor
Aug 26, 2015 06:17 PM
muttleytm
Jul 14, 2015 05:31 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fatih717171
Jul 8, 2015 12:14 AM
