help: no power to deck
Old Dec 19, 2004
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
alright, my deck was working perfectly for about two years.. a few months ago it became locked on one station.. i couldn't change the volume, the station, play a CD.. nothing.. and the lights on the deck barely lit up.. now, no lights light up and nothing plays, so i'm guessing it's receiving no power.
what can the problem be?
can it be a problem with the battery? cuz when the bass used to hit the headlights dimmed.. and when i use the power windows sometimes the headlights dim too. any help is appreciated. thanks.
Old Dec 19, 2004
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
try taking out ur deck and recheck all ur connections.. maybe ur deck is just old and just broke! I dunno! hopefully someone here can help you out a little better! Good luck!
Old Dec 19, 2004
PK2K1's Avatar
i'll try that again sometime.. it's just too damn cold out to do any real troubleshooting right now..
i hope the deck isn't finished.. it ain't that old.. it's one of the older mp3 kenwoods.. like 3 years.
Old Dec 19, 2004
skiboard's Avatar
My deck isnt working at all after cold hit us too
no power at all, I tried changing to original deck, and checking the fuses, still no power. hmm anyone knows how to solve this problem?
Old Dec 21, 2004
PK2K1's Avatar
anyone?
Old Dec 21, 2004
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
PK2K1, Sounds like its time for a new deck. The dimming of the headlights is attributed to excessive current draw on the system. You'll notice it most on the headlights as they draw a decent amount of current. Throw in some windshield wipers going and power windows and you should definitely see it. This is not so much a problem with the battery as it is with the alternator/charging system. If you want a relatively easy solution for the current draw issue upgrade the alternator ground (its only like 10 ga stock) and engine ground (braided line right in front of you with hood open) to a good 4 ga wire.
As for the deck itself, it may be a fuse, but dont expect the lights to be functioning. The only effect the cold would have on it would be worsening a preexisting problem on the circuit board. I have an Alpine CDA-9833, and on the coldest of days (-2 this morning) the display takes a couple of minutes.
Old Dec 21, 2004
PK2K1's Avatar
alright, i checked the fuse.. it's ok.. i took the deck out and made sure everything's properly plugged in..
MassMayhem, thanks for your help. dumb question.. but is there 2 grounds that you're talking about (alternator and engine) or is that one wire?
Old Dec 21, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
pk2k1, when you say checked the fuse does that mean you used an ohm meter to make sure it was good? Or did you eyball it? I just ask because sometimes it can blow and eyeballing it doesn't detect it.
Old Dec 21, 2004
PK2K1's Avatar
no, i just looked at it... i'll test though.. thanks
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
BootyDo
Jul 26, 2015 10:38 AM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
