Power Wire Question
Old Dec 7, 2004
4BDN_CIVIC's Avatar
4BDN_CIVIC is an unknown quantity at this point
Power Wire Question
hey guys i have my whole system setup, but i am having extreme difficulty finding a place to run my power wire through the fire wall....i was just wondering if i can get some help from anybody.
Old Dec 7, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Lots of threads on this issue. most people go through the firewall on the passenger side.
Old Dec 7, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Check out the DIY
Old Dec 7, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
In the DIY it shows you where the grommet is in the passenger floorboard. I'd use that...
Old Dec 7, 2004
patau13's Avatar
Big Member
patau13 will become famous soon enough
Find the gromment with the DIY, stick a needlenose plyer thru from the inside and open (you need 2 people for this), then reach into the engine compartment, feel w/your finger for the needlenose and stick the end of the wire in the plyer, tell your friend to squeeze and pull.
Old Dec 7, 2004
EnProceso's Avatar
i used the drivers side, well i didnt, my friends shop did.
Old Dec 8, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
drivers side. sounds like they made it tougher on themselves. The battery is on the passenger side, so it's just more efficient to go through that side. Pull your carpet back under the dash and you'll see a wad of wires behind there. That would be where you would poke a hole through for your own wire. BECAREFUL though.
Old Dec 8, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
the passenger side grommet referred to in the DIY in my 01 ex coupe has solid metal behind it - no hole. I ended up sharing the drivers side hole rather than bore a new one. Be careful is right - you don't want to damage any of that wiring.
Old Dec 8, 2004
MegaHurtz's Avatar
passenger side where all the wires come through
i've got 4awg thru there without TOO much trouble
Old Dec 8, 2004
tom1178's Avatar
tom1178 is an unknown quantity at this point
Passenger side is a few dollars cheaper too!! A couple feet of thick guage wire isn't exactly cheap. I pulled my 4 guage through duck-taped to a coat hanger (had to do it by myself)........I wish i had somebody to hold pliers for me.
Old Dec 8, 2004
Word.
Depending on the manufacturer of the wire and the shop you get it from at least. Our shop carries JL Kits and Stinger on the spools.. the 4 awg Stinger is $2 a foot.. and the JL 4awg kit comes with I believe 18 feet of wire and is $140 or so?
The Stinger 0/1 awg is $4 a foot. Considering if you run it through the driver's side.. you will need at least an extra 10 feet (depending on the route through the engine bay).. that's an extra $20-$40!! Save yourself the cash and go through the passenger side.
Old Dec 9, 2004
cordeez's Avatar
Member
cordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trusted
damn, i though that was impossible
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
bsmiley
Apr 27, 2015 01:27 PM
darwin-t
Apr 18, 2015 09:29 PM
MyCivic
Nov 21, 2001 02:11 PM
