Help with wiring trunk opener
Old Dec 5, 2004
aznrocka's Avatar
aznrocka is an unknown quantity at this point
Does anybody know how to hook up the wire for an Audiovox/Prestige APS996A
so I can use the alarm remote for the trunk opener? I did the DIY for the trunk
opener (installing a 98-02 accord trunk latch into my civic) but I haven't
been able to figure out which wire to hook up.
Old Dec 5, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if your alarm outputs a positive signal, then your set, just hook the blue wire on the opener to whichever output wire your manual says for the alarm. Most alarms output a negative signal. you'll need a relay to hook the two together. If you look at the relay, their are 4 prongs, one side has the picture of a coil, the other or a open latch. on one side put a constant +12 volt line and the alarm output wire. On the other side, ground one prong and attach the blue wire from the trunk opener to the other prong. If you can wait two weeks, im going to be installing mine and can take any pics you might need.
Old Dec 5, 2004
aznrocka's Avatar
I've read the manual multiple times and can't figure out which wire I'm suppose to hook it up to.
http://www.audiovox.com/webapp/wcs/s...2870&langId=-1
That is what I have and u can find the manual on the site too. I have the relay that came with the trunk latch. But I can wait two weeks. I've been tring to figure this out on my own since Oct.!!! Pics might help me a lot. Thanks in advance. Any help is appreciated.
Old Dec 5, 2004
dark blue wire, its on page 13. its a negative output, so your goin to need the relay
Old Dec 6, 2004
gimmegimme's Avatar
gimmegimme is an unknown quantity at this point
I've been wanting to do this too, but the Accord trunk opener has been discontinued by Honda. Anyone know where I could get one?
Old Dec 6, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
How could they discontinue it? How do you fix your accord?
Old Dec 6, 2004
aznrocka's Avatar
Thanks grenloch101056. I'll try that. If I can't get it then i'll wait til you can still get some pics up for me.
and how could they discontinue it gimmegimme? anyways, i got mine here http://www.handa-accessories.com
you can also get it from honda and other places that sell honda parts
Old Dec 7, 2004
gimmegimme's Avatar
I've checked with a Honda dealer in Toronto (Canada) and partznet.com. They both told me it was discontinued by Honda. Supposedly, it's an accessory and can be discontinued at any time. It doesn't make sense to me either... as tbaleno said, how are you supposed to fix your accord if it breaks?? I couldn't find it at HandA either.
Edit: I just checked HandA again and it's there.
Old Dec 7, 2004
you could always scour a junkyard for one, that is pretty dumb that they canceled a part
Old Dec 7, 2004
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
use the channel 3 or the dark blue wire some dude mentioned above.
the actuator will have two wire, ground and 12volt switch
ground- ground to chasis
use a relay, SPST(find at radioshack $4) or SPDT($1 online)
85-channel 3 or dark blue
86- 12v constant fused
30- 12v constant fused
87- 12volt switch
Old Dec 7, 2004
he has the accord trunk opener, which grounds itself through the mounting point on the trunk, so it only has one wire coming off, the 12v wire
Old Dec 7, 2004
aznrocka's Avatar
thanks for the help guys. i'll try it when it stops raining here in MD. and the trunk latch came with a relay so i can use that
Old Dec 9, 2004
cordeez's Avatar
Member
cordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trusted
i seccond that ^
Old Dec 10, 2004
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
I would use a single pull double throw relay (SPDT). Also get a trunk pop motor from any car stereo shop that installs alarms.
Install SPDT relay near alarm like so:
Post# 86 to 12+ constant. FUSE this wire!!!! 10 to 15 amps is good.
Post# 85 would hook to the blue wire that is from the alarm
Post# 87 hook to 12v+ with wire from 86
Post# 30 goes to the trunk pop motor.
Run a wire from the relay near the alram to the trunk pop motor in the trunk. The trunk pop motor will have two posts, one comes from the relay from post 30 the other goes directly to ground.
Hope this helps!
Old Dec 13, 2004
buddyclub's Avatar
buddyclub is an unknown quantity at this point
this isnt about wiring, but do you buy the 2dr one or 4dr one on handa-accessories?
Old Dec 13, 2004
i bought the four door model
Old Dec 17, 2004
aznrocka's Avatar
I dont know if it matters. It might be the same but I bought the 2dr model.
mohawkboom
67
Aug 25, 2015 12:28 AM
Youshoe
May 22, 2015 09:36 PM
Dmitri
123
Oct 13, 2005 08:01 PM
Juancho007
Dec 16, 2001 01:02 PM
