Lost my link. Fiberglassing to ABS Plastics
Old Nov 30, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I had a link to a fiberglass product that worked particularly well to ABS Plastic. I've lost it. I tried searching for it again, no luck. Anyone had good success bonding fiberglass to ABS Plastics? If so, what did you use?
Old Nov 30, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I'd like to know as well. I'm working on a gauge cluster and I need to make modifications and fill it. I was thinking fiberglass but I don't know how much the hardener will melt the ABS.
I'm going to have to give you some Rep points for asking this
Old Nov 30, 2004
AlpineCivic's Avatar
The trick Ive always used was drilling holes into the plastic so that the Fiber Glass sticks on both sides (Alpine uses this technique). Ive never had a problem.
Old Nov 30, 2004
tbaleno's Avatar
what about plastic melting? Is it a problem? I heard the hardener mixed in the resin gets hot and melts plastic. Is this true?
Old Nov 30, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
The MEKP accelerant mixed with the resin does tend to get a little warm. I seriously doubt it's enough to actually melt the plastic. Maybe warp it, but not melt it. I'm sure you can find what you're looking for here j187:
www.selectproducts.com
Old Dec 1, 2004
J187's Avatar
I knew about that but wasn't sure how well it worked. How many holes are we talking?
Pop, thanks for the link. I've been meaning to try out SP.
Old Dec 1, 2004
LudlamTheory's Avatar
i boogie for the raindrops
drilling hoels works badass... ive used it too...
Old Dec 1, 2004
J187's Avatar
good to know. The more I think about it, I'm thinking of trying something new. Bondoglass. I think it might be a lot easier to form to mold for this particular profect. Anyone work with BondGlass before?
Old Dec 1, 2004
I don't really like it that much. It's about the same consistency as mayonaise with hair in it. I'd use weave for a few layers then go over it with a couple of layers or dynalite (or another liteweight body filler).
Old Dec 2, 2004
A lot of holes.....
Old Dec 2, 2004
WhiteRabbit's Avatar
kitty hair would require holes too.
you can just scuff the CRAP out of the plastic. but I wouldnt do that if you plan to paint.
I dont know if you really already have the cloth stretched or not. but lets pretend that you do.
id sure hate to dissasemble everything just to drill holes!
but you can just resin your cloth, no worries about adherrance. THEN drill holes in plastic (but not your hardedned cloth!) and fill with kittyhair.
strength of holes drilled (make sure they are large holes) without dissasembling your cloth.
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
General DIY
Sep 25, 2015 08:02 PM
jsmithe2010
Sep 25, 2015 07:42 PM
Jrosa
Sep 14, 2015 08:24 PM
