New battery install
Old Nov 16, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
New battery install
Well, I got desperate. Apparantly my stock battery died a horrible death. So I ended up having to finaly install the SVR 75 I bought. The problem is it's a bit bigger than stock... Okay its a LOT bigger than stock. I had to remove the plastic tray and cover.
I have a question though. Is it okay to just have a tie-down across the top of the battery or do sanctioning bodies for car audio want more stability. The battery isn't going anywhere since its jammed in there (I don't know how I'll ever get it out to change it )
Anyone have opinions?
Old Nov 16, 2004
MegaHurtz's Avatar
it should be fine with the stock tie down
what is with everybody removing the plastic tray?? I left mine in, but I did do away with the cover obviously
Old Nov 16, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I kept my tray too.. but as long as the battery doesn't move around, you should be alright.
Old Nov 16, 2004
MegaHurtz's Avatar
ya its just to keep it off the metal, maybe to collect battery acid
Old Nov 16, 2004
LudlamTheory's Avatar
i boogie for the raindrops
mine wouldnt fit on the tray
Old Nov 16, 2004
tbaleno's Avatar
I wish I had a camera. I tried to fit it in the tray but it was over the edge by about 1/2 inch. At first my IMA light was on. Now it went off and the cel is on
Old Nov 16, 2004
WhiteRabbit's Avatar
dont mention you had to remove the tray when you compete
Old Nov 16, 2004
tbaleno's Avatar
maybe I should just fiberglass a tray. I don't know if it will raise the battery too much though.
Old Nov 16, 2004
I took my tray out even tho the battery would fit. It just takes too much side room and I needed clearance with hid wiring. I don't think the battery will fall out tho
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
