Installing dynamat
Old Nov 8, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Installing dynamat
Is there any diy's on installing it?
Old Nov 8, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
http://www.dynamat.com/auto_install.htm
Old Nov 8, 2004
Yup easy enough. I would get the dynamat extreme because it sticks better. I also used a heatgun when applying, but it's not a must. A roller is pretty much required to get it on good. I did my whole car over a year ago and that stuff hasn't moved at all.
Old Nov 8, 2004
J187's Avatar
http://www.7thgencivic.com/forums/sh...ad.php?t=84562
If you haven 't already bought Dynamat, check this?
Old Nov 8, 2004
Blahman2's Avatar
I don't need it for my speakers. I want it for my trunk because when I have music with tons of base it rattles like ****. I want that to stop. Maybe I'll try to tighten things in my trunk also... But I have some across a large sum of bestbuy bucks, and bestbuy sells dynamat so thats why i'm buying it.
Old Nov 8, 2004
Start by adjusting the rubber stoppers on the lid to make it close better.
Old Nov 8, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Try the Sound Deadening DIY at the top of the page. It's stickied there in plain sight for a reason. IBTL
Old Nov 9, 2004
Blahman2's Avatar
actually, since I looked into this. I'm just going to get the kind of dynomat that goes around the speakers on the door and the rear deck. Because I just bought more powerful speakers and I think this would help me out quite a bit. Then I will do the sound deading on the trunk. But do you think installing dynamat in the trunk itself really helps? Like sound quality wise?
Old Nov 9, 2004
J187's Avatar
doing the doors around the speaker is huge. When I did my door speakers, I didn't have time to start and complete all at once. I did the dynomat first, then stuck my stockers back in jsut to have tunes while I drove until I could finish doing my quarts. The sound actually noticeably improved in the stock speakers just from the dynomat.
Old Nov 9, 2004
Yes big improvement with speakers. Even the trunk is worth it, but you need to do the lid to reduce rattles. I didn't tho cause it would look ugly.
Old Nov 9, 2004
Blahman2's Avatar
i think dynamat in the trunk looks cool actually
Old Nov 10, 2004
WhiteRabbit's Avatar
big important warning here, there isnt 100% chance you will stop your trunk rattle with dynamat. theres an inner frame that vibrates agasint the trunk lid skin, and theres more than one member here who has PM'ed me with rattle problems post deadening to ask why their trunks were still rattling!
if you want to be 100% sure your trunklid will be dead solid, follow these steps:
#1 foam the lid (the rest can be done out of order)
to foam the lid, simply grab a can of spray expanding foam. I like minimal expand because theres a TON of room for user error, although triple expand works great too. as does normal expand. theres no bad type of expanding foam to use in this situation!
cover everything you dont want stuff on. its sticky as HELL! then stick the nozzle between the frame and the skin and spray away. it wont take much. most certainly dont fill teh entire cavity with wet foam, it expands!
afer the lid is foamed, trim off the excess so the deadener will apply evenly.
then:
apply sheet deadener on the lid
adjust the stoppers and/or latch to achieve a tight seal
use weatherstripping on your liscence plate and frame too if neccesary. please.
guaranteed to kill 100% of trunk lid rattles if applied properly (lud will tell us if there are special precautions for sedans due to brake lights)
Old Nov 10, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
True.
Has anyone here deadened the rear deck rattling? I don't know if this is just me, but my rear deck hops up and down like a caffeinated jackrabbit and the brake light hump in the middle hits the rear window and makes a horrible rattling noise. I have solved the problem temporarily by using what I call the Rand McNally Technique, which is achieved by jamming a New England Road Map into the space between the deck and the window.
I need to figure out my trunk leak before I take my deck off , but has anyone deadened the deck before? Did you use dynomat, foam, tape, rubber bumpers, true love?
Old Nov 10, 2004
Blahman2's Avatar
a very thin strip of weather strip of some sort would work well. Or you can make a custom rear deck out of fiberglass. Personnally I would love to remove my brake light in the window. Its useless, its not connected. I got the brake light on my spoiler.
Old Nov 10, 2004
J187's Avatar
then:
Recently saw a 2001 Civic with 2 L5s. Dynomat done to the lid, still rattled like a bitch. Hence, heed this warning. The kid asked me if there was something he could do, I told him to foam it.
J
Old Nov 10, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I have like 150+ feet of fatmat in my car and I don't have any rattles. Just don't use big pieces . . . cut it up into smaller pieces and puzzle it in there. I used felt dots for the license plate and that got rid of all the rattle from that, and tighten the trunk latch and you should be allright.
I also got rid of my stupidly loud system and went for sound quality this time around . . . but even when I had the loud system it didn't noticably rattle.
Old Nov 11, 2004
I carpeted my rear deck, now it makes no noises when it contacts teh windshield. ive done it in other cars without carpet just stuffing carpet or towels or even socks between the deck and the window, below the visible line, to prevent contact.
Old Nov 11, 2004
bakuretsu's Avatar
I'm with you on that. Right now I'm using the Rand McNally approach, but I liked the weather stripping idea and I happen to have some lying around so we'll give that a whirl before moving to carpet.
Old Nov 12, 2004
I fatmatted my rear deck. I actually took the deck out to deaden it from the top. I have it in the flat places on the bottom as well. It helped considerably, but I would like to take the tension springs or whatever they are called(form the X between the trunk hinges) out completely, I wrapped mat around them as best I could, but they still rattle and resonate.
Old Nov 12, 2004
I still get rattles, but I think it's from the trunk lid that I didn't do.
Old Nov 12, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Gearbox, just deaden it and then make a fiberglass mold of the underside of the lid, trim it all pretty, smooth it with body filler, carpet it and attach it...coveres the deadener, and looks even better than stock.
Old Nov 12, 2004
torsion springs or torsion bars, for the terminology
as for the trunk lid, I think a flat board would do much better, and far easier.... like .25 inches
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
