Spark
Old Nov 7, 2004
fonto's Avatar
The LA Clipper
Spark
Do you guys get a spark when you disconnect you negative on you battery and reconnect it? I have not had this happen before (from what I can remember), and it kept happening the other day. Is this a sign that something is wrong?
Old Nov 7, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I usualy get sparks.
Old Nov 7, 2004
MegaHurtz's Avatar
same
Old Nov 7, 2004
fonto's Avatar
The LA Clipper
ty
Old Nov 7, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i did it a couple weeks ago and i didn't get any sparks....i was expecting to see some sparks, so when i connected the negative terminal, i tried to do it as swift and quickly as possible...
Old Nov 8, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Sounds like you disconnected the possitive cable first. You should definitely disco the negative side first, then you won't get sparks. Theoretically, sparks could ignite the gasses inside the batter and blow that **** up in your face. Sound like a longshot? Then why'd I spend a night in Mass eye and ear infirmory with my brother when it happened to him? Strange things happen. I'm not one known for my everlasting caution (I drill and grind without safety glasses, I take my helmet off at the NH Border on my Bike etc.) But I do respect electricity and eplosiveness
Old Nov 8, 2004
82801BA's Avatar
82801BA is an unknown quantity at this point
Seems like disconnecting the positive(only) is a better choice....I don't see why ppl disconnect the negative side when installing ICEs(still breaks the circuit anyway, and a good ECU reset too)....I always disconnect the positive lead on the battery(remove the fuse).....
But I've never seen any spark when discconnecting/connecting the negative lead when the positive is removed....
Old Nov 8, 2004
fonto's Avatar
The LA Clipper
I did not disconnect any other wires first...I disconnect the negative in order to install a new HU.
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
Bman2212
Sep 2, 2015 11:49 AM
