can i run 3....
Old Nov 2, 2004
nolimitrican's Avatar
nolimitrican is an unknown quantity at this point
can i run 3....
Can i run 3 12in kicker comp vr's 4ohm w a 800.2 kicker amp?
Old Nov 2, 2004
thoughthard's Avatar
thoughthard is an unknown quantity at this point
The Kicker KX800.2 - four ohm minimum running mono
You pry could mix parallel and series wiring to achieve a minimum 4 ohm.
I can't think right now, so more help from me at this point.
Old Nov 2, 2004
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
are you sure it's not a 800.4 instead of a 800.2?...anyway, check the diagram below...that presents a 2.67 ohm load to your amp...as posted, the KX800.2 is only stable to 4 ohms mono...so that kinda sucks for you...you could just run 2 of them, as in the second diagram, and sell your 3rd sub for a few extra bucks...or just get a new amp...anyway, good luck!
Old Nov 2, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I'd sell all three woofers and buy an L7.
Drive your 800.2 mono @ 4 into a 4ohm L7 looking for around 750watts . . . mmmmmmn
Old Nov 2, 2004
...or you could do that...i have a pair of S12L7s pushed by a Kicker KX1200.1 that's putting out 1410 watts at 1 ohm...
Old Nov 2, 2004
The closest I can calculate is a 4.33 ohm load, but one sub would be wired weird, so I am unsure if one voice coil will get different wattage than the other.
Old Nov 2, 2004
i wouldn't chance it, bro...right now you can get a KX1200.1 from sounddomain.com for a little over $400...or check out the Hifonics Brutus BX1000D or BX1500D...all Hifonics' amps are stable to 1 ohm, and they put out awesome Class D power at a great price...good luck!
Old Nov 4, 2004
i think im gonna keep 2 right now, i like that idea w da L7, u think da L7 will hit pretty good j187? i probably gonna be selling my other kicker comp is still in da box let c what happens...
lilrob1213
37
Jun 29, 2015 06:45 PM
hokiedad4
May 3, 2015 10:06 PM
dragonsblood
Apr 27, 2015 12:28 PM
Dmitri
123
Oct 13, 2005 08:01 PM
JoeB16
61
Oct 16, 2003 07:58 PM
