Biggest amp for stock alternator?
Old Nov 4, 2004
  #31
MegaHurtz's Avatar
Originally Posted by LudlamTheory
out of curiosity, arent you in street class?
to my knowledge you aren't even allowed to turn the car on, so for competition purposes, unless you upgrade to super street, an alternator is useless. for daily driving, i'd personally invest in a sealed battery for the trunk, and id definitely upgrade your alternator wire. stock honda wires blow ***.
Yes in dB Drag I am street, but in IASCA I am in stock where I AM allowed to run the car, and I prefer IASCA to dBDRA any day. I wouldn't want an upgraded alt so much for competitions as I would want it for daily driving to keep everything up to par at its peak level.
Old Nov 4, 2004
  #32
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
An HO alternator would be the first thing i would do... How do you think a battery gets its juice, it doesnt matter how big your battery is, in fact the bigger it is the more strain it puts on the stock alternator. Just wait people, those alternators are not that strong. I have been in Car audio for a long time. (about 12 years)
Old Nov 4, 2004
  #33
WhiteRabbit's Avatar
http://www.betteraudio.com/geolemon/newmain/battcapalt/
suggested order of upgrade and more importantly, why. alternator comes last.
Old Nov 4, 2004
  #34
"It can be harmful if you see your headlights dimming darker, and darker, and darker each time... meaning your battery discharge exceeds your battery's charge time.
That's definitely a sign that your listening habits are warranting an alternator upgrade.."
It all depends on how you use it and how much amperage you are drawing.
This can also be seen if you are running too powerful of an amp for your electrical system.
Old Nov 4, 2004
  #35
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I disagree with the cap being added before upgrading your battery or adding a second one. Batteries are about the same cost as a decent capacitor.
Old Nov 4, 2004
  #36
absolutely. true without a doubt, which is the point of why he said that. more evidence to support his claims.
as to the cost factor of cap versus alternator, its a crapshoot. read the article, It should state that they do different things, and each serves a different purpose. if you are buying a battery to cure dimming, a cap may be an easier alternative, and potentially better able to do the job.
but to those of us who want to watch a movie with the engine off, its much easier to see a cap would be a terrible way to do that!
a little off topic, but thats how I prefer to discern whether or not a battery or capacitor is more or less appropriate.
Old Nov 6, 2004
  #37
DragonAce's Avatar
DragonAce is an unknown quantity at this point
i'm doing 2700w with stock alternator (2x1200@12v D class + 1x300@12v D class..)
using a stinger 200a isolator, 3 farad cap and a 51R in the trunk..
only voltage drop running is at MAX volume..drops from 14v to maybe 12.5v and light never dim..
was initially worried about an alt. but as of yet see no need to really research it thoroughly
Old Nov 8, 2004
  #38
fastcivic03's Avatar
fastcivic03 should not be trusted
how bout a jl 1000/1 amp and an optima yellow battery shud i see any problems wit my alt? if so how much is a new one
Old Nov 8, 2004
  #39
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
^no, you will be more than fine
Old Nov 8, 2004
  #40
LudlamTheory's Avatar
i boogie for the raindrops
thats also because your audiobahn amps will only do the 1200 when theyre struck by lightning
Old Nov 8, 2004
  #41
HondaSales's Avatar
^ Lol
Old Nov 9, 2004
  #42
DragonAce's Avatar
and??
i wanted 1200@1, i got 1200@1..
got a great deal thru the distributor to boot..
what you running btw??
Old Nov 9, 2004
  #43
and??
i dont think you got my comment
Old Nov 9, 2004
  #44
DragonAce's Avatar
if it wasn't meant as something cynical then i apologize..
people generally luv to slam bahn stuff and i took it as that's what you were doing..
if i'm wrong, my bad..
Old Nov 10, 2004
  #45
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
slam dunk
Ludlam makes his point about overrated wattage on Amps. I guess if you took offense to him pointing out you're not getting anywhere near 1200 RMS, then so be it.
Old Nov 10, 2004
  #46
^ agreed!
jru27
Jun 19, 2015 03:51 PM
jackoncruzpr
May 24, 2015 12:24 AM
cloudguy
Apr 28, 2015 05:02 AM
smmahan
Apr 15, 2015 08:17 PM
