Wave length
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
Wave length
How long is a wavelegth for about 85-90 hrtz?? I can't figure out why I have such a sharp freakin dip at this frequency...I have tried underlapping and overlapping, and that doesn't seem to help. i tried reversing the polarity of the subs, but that then creates a small dip at the x-over frequency.
the only thing I can think of is that I hold my meter in a bad spot where the two midbasses cacel each other out, and cancel each other out even more with the sub bass on.
Old Oct 28, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
roughly about 12 - 13 feet.
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
cool, thanks
Old Oct 28, 2004
LudlamTheory's Avatar
i boogie for the raindrops
speed of sound at sea level = 1129 feet / second = c
frequency = 85 Hz = 85 cycles/second = f
wavelength = unknown = λ (greek letter lambda)
v = fλ
or
λ = v/f
so
λ = 1129/85 = 13.28 feet
now dont ever ask me how to do that again mike =)
Old Oct 28, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i love the way ludlam drops knowledge like that! (not being sarcastic)
Old Oct 28, 2004
< ----------------- future high school physics teacher (bout a year or two, depending on money)
my goal is explaining it once thoroughly so ill never have to do it again, but it never works....
Old Oct 28, 2004
J187's Avatar
Damnit, this happens to me all the time in school! I had the right answer but didn't show my work! Arggggg.
Just incase anyone wrote down that forumla (which you may want to do) that C is supposed to be a v, it's just a typo.
Old Oct 28, 2004
no, the c is a c, because its a constant
when dealing with absolutes such as wavelengths in light and or sound, one uses c
if you just used it as a general formula, then v would be proper
Old Oct 28, 2004
oh, mike, are you still running your q-forms free air? like have you at all sealed up the backs?
if so, that may be your issue
EDIT:
just remember you have the kicker rmb6's
im still thinking it has something to do with those guys
Old Oct 28, 2004
J187's Avatar
Oh, my bad. I saw it as the general formula and thought since the letter c is right next to the v on the keyboard. . .
Old Oct 28, 2004
J187's Avatar
Lightbulb
Hmm, Good topic. I won't hijack though, I'll start a new thread.
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
EDIT:
Yeah, Maybe...I did not have a dramatic drop with the Infinitys, but the Infinitys did not thump nearly as hard. The RMB6s kick but in the 110-140 region, but start dropping quickly at 100 with the x-over at 70 hrtz.
Old Oct 28, 2004
Ed's Avatar
Ed
i'm impressed, you even took the time to use the real lambda symbol
Old Oct 28, 2004
would you happen to have any t/s parameters for those kickers on hand?
Old Oct 28, 2004
J187's Avatar
He probably wouldn't considering kicker only discloses T/S for their "sub" woofers
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
Here is the technical info for the RMB 6. It has a lot more info then the actual manual, but I don't see any T/S parameters...only a lot of graphs
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
I'll prolly end up boosting 80hrtz with a high Q, but I don't like to because it will add sub bass and prolly cancel out the mids even more.
Old Oct 28, 2004
J187's Avatar
Technical manual = no T/S though.
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
You know what it could be...My subs response drops off the face of the earth above 70 hrtz ever since i ported them (although I am very happy with how falt the response is from 35-65 hrtz...like +/- 1 db). The Mids in in the door prolly start to drop at around 100hrtz. So maybe neither of my speakers (Subs and Mids) can adequately cover 85-95 hrtz.
I can try two things if this is the case...either overlap a lot, or boost a few DBs at 80 (but this also boost the surrounding requencies, and my loudest fequencies are at the 120 and 50 hrtz areas).
FYI, my mids alone will play at 89 dbs at 15 on the volume, but with the bass on it plays at 85-86 dbs. I have tried to make all of my midbass between 90-94, so 90 is less.
...man, i like to ramble
Old Oct 28, 2004
i have never been impressed by the kicker rmb6's
pm me though or get me on aim, i might be willing to lend you some drivers to test in your doors to see if it helps
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
Thanks Lud, I wouldn't want to rust your drivers in my leaky as door...anywayz, I bought them because they were cheap and I didn't want to spend a lot for midbass in my door...In a few months I may think about some new ones...but I am actually really happy with the kickers (even though the speakers are not as solid as my other speakers), but they play resonably flat, except for a peak at around 125 (which I like), and a dip at 90 (that I don't like)...they are funny though because they peak again at 60...so even thoug they are x-over at 70, they have the same output at 60...but they drop from 100 to 70hrtz
...and you know me, I hate the install part of audio...but I will check with yall for suggestions if I get new drivers...midbasses are not too expensive...but I did get those kickers for only $109.
Old Oct 29, 2004
are you independently amping them?
or using a passive with the ti's?
Old Oct 29, 2004
fonto's Avatar
The LA Clipper
I have the speakers set up as follows:
PG Ti 600.2 for Ti Elite Speakers (185 hrtz and up)
JBL PX 600.2 for Kickers (70hrtz-185hrtz)
JBL BP1200.1 (JBL BPX 1100.1 sitting on couch waiting to be installed) for Maxes (20-80hrtz with a 20 hrtz subsonic). I have tired the lowpass at 60 and 70 hrtz, and I tried it at 80hrtz and I like the bass midbass transition a lil better. However, my bass out put starts to drop at 65 hrtz and above.
I like the way it currently sounds, so I am gonna try it for a few days and see how it goes. I should really wait until install my new amp before i do my "final" tuning.
Old Oct 30, 2004
hmm
maybe
you could try a dctt enclosure
GotSiR
Jun 23, 2016 04:06 PM
alaga
Feb 28, 2016 02:19 PM
Sep 27, 2015 11:33 AM
rnaodm
Sep 21, 2015 12:42 PM
blward6
Sep 16, 2015 05:32 PM
