windows
Old Oct 26, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
windows
Okay guys quick question...you guys know how in the EX the driver side window automatically comes down if you just press it once but the passenger window (if your in the driver position) you have to hold it down....btw im talking about coupes....is there anyway I can buy like the motor of how the driver side window works and make the pasenger window like that? so with one click it can come all the way down from the driver side....and passenger side that would be nice too
Old Oct 26, 2004
MegaHurtz's Avatar
It's all in the switch, not sure if it can be done the same for the passenger side but would be neat to see
Old Oct 26, 2004
MegaHurtz's Avatar
Try it out, let us know and of course MAKE A DIY!
Old Oct 26, 2004
Yup it's the switch. It won't be easy to mod something like that tho, unless you rebuild the switching mechanism. Prolly impossible unless you have the resources and know how.
Old Oct 26, 2004
NaSh123's Avatar
ya I had the idea and it would be really cool....I wonder can't i just purchase the switch ? like a driver side switch and place it in the passenger slot?
Old Oct 26, 2004
MegaHurtz's Avatar
Or you could buy the switch
Old Oct 26, 2004
NaSh123's Avatar
i think what i'll do is buy the switch but i can always expirement with the old switch and see if i can make a DIY to change the current ones to work the way you want it to work....my uncle works for GE so he knows a lot of electrical **** i could ask him to help me maybe
Old Oct 26, 2004
NaSh123's Avatar
how much would the switch cost any idea?
Old Oct 26, 2004
It's all integrated. The switching mechanism is on the circuit board. Have fun
Old Oct 26, 2004
See those little plastic white things sticking out? Depending on how they move, the window will roll down (forward), stay still (middle), or roll up (back). Now you may be able to buy a second switch that says auto and just swap it? But I don't know if it's the switch of the design of the sensor on the board that keeps it rolling. Remember that the switch kicks back up even tho the window is rolling down I think. See pic.
Old Oct 26, 2004
NaSh123's Avatar
hRm... might be harder than I think...I think my uncle will know what to do though...he plays with those things all day long....how much is a switch if I just want to buy it, any idea?
Old Oct 26, 2004
NaSh123's Avatar
I c....I think i'll call honda and ask them ...you think any of them would know anythign about it? or are they all just idiots?
Old Oct 26, 2004
I think you need to buy the whole assembly. They don't sell just the switch.
Old Oct 26, 2004
NaSh123's Avatar
well whatever it would be....I wonder how much it is....also if I buy a new one i Wonder if i'll be able to tell what the difference is in the design of it to be able to mold the old one to work the way the automatic one woudl work
Old Oct 26, 2004
Check if the switch stays depressed until the window rolls down completely. If it pops back up when you let go before the window goes all the way down, then it's not the switch that does it.
Old Oct 26, 2004
NaSh123's Avatar
makes sense...I guess I'll call honda and see what they say about it...and if they will want to void my electrical warrenty if I do that lol....btw gearbox did you have that picture or did you just take it? and if i did have that pic have you like taken a picture of every bolt on ur car?
Old Oct 26, 2004
That was from when I did blue dash lights. But yeah, I like taking stuff apart.
Old Oct 27, 2004
2k2civic's Avatar
I recently purchased the window roll up/down module for my alarm and found that the relays somehow being tripped when I hit the window switch on either driver or passenger side and go auto all the way up or down.
Old Oct 27, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
this may not work but......in my old car (2001 audi a4) there was a simple diy that allowed you to make all ur windows auto down.....it came stock with the rfront two but the rears were not. This may work on our cars as well and it may not.
the mod was simply take off the window motor and then unplug the harness within the motor there would be 4 pins, u take some speaker wire that is raw and then do a figure 8 around the pins, place the motor back on and whala!!! it may work i am not sure.....dont ask me how someone found it out i thought it was strange people were puting figure 8 of speaker wire within a window motor anyhow.
if u need detailed instructions u can go to audiworld.com and then hit up forums and b5 a4 forum then search away.
if it works someone let me know and i wil do this mod again!!! if it does work then this would be hot on a 4 door too.....i know i loved it and people were like dan how did u do that
Old Oct 27, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
buy an rsx which has that option stock
cheaper solution would a be window roll down mod for your car alarm
Old Oct 27, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Dude did you know your stock keyless entry on your A4 could be reset with merely a button sequence to roll all your windows up and your sunroof when you locked your doors?
Old Oct 28, 2004
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Go buy a DEI 530T(its an window automation module for alarms), even if you dont have an alarm, it will give you one touch up and down on 2 windows. if you want to have one touch from the passenger switch too it can be done, but you'd have to run some wires from the pass door to the module.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
Rexall
Sep 11, 2015 02:30 PM
