Alternator whine.. in only one speaker!
Old Oct 26, 2004
o2civic's Avatar
o2civic is an unknown quantity at this point
Ok.. what gives?
I have that high pitch sound in only one speaker.. The passenger side..
I have the Kenwood exel#$#$ component speakers..
Any ideas why or where to start figuring this one out?
thanks
Old Oct 26, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
Try ground. Thats where most alt whine comes from. It may just be a fluke that it only appeared in one speaker. If that doesnt do it check the wiring for that speaker to see if it is run near any power wire or other wiring that may crosstransmit sound.
Old Oct 26, 2004
brash's Avatar
brash is an unknown quantity at this point
I have this exact same problem. I regrounded REALLY well, the power and RCA cables are separated, and I still can't figure out what is wrong. I finally just turned down the gain on my amp. I can still hear it, but not as much.
If you figure out what is causing your problem, let me know...
Old Oct 26, 2004
ohiojosh78's Avatar
That also usually helps. Turning downthe gain. Unless you're going into an SPL comp. no need to be past halfway on the gain.
Old Oct 27, 2004
rinsincivic's Avatar
rinsincivic is an unknown quantity at this point
sounds to me like you may have a speaker wire grounding out i had this happen once before
Old Oct 27, 2004
brash's Avatar
That is just masking the problem, not solving it.
Old Oct 27, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I just feel as though thats a little too general. Gain settings depend entirely on factors like source and amp and even preference. There really isn't a way to say that gains should never be 3/4 of the way, or always 1/8 of the way etc, you tune the gain to your particular settings whereever they land, the land.
I do agree that turning down gains that are set rather high can lessen whine.
Another common cause of whine that is often overlooked is a breach in the RCA Cable. Plenty of people ruthlessly drag and pull RCA throughs openings and around screws and bolts. I'd check the cables themselves too.
Old Nov 28, 2004
Corey291's Avatar
Corey291 is an unknown quantity at this point
This may make you laugh,
Is your power wire routed with the speaker wire going to the passenger speaker?
I have seen this situation come up in the past with some high current draw amplifiers and larger replacement speaker wire.
I also agree that a grounded speaker wire or terminal could also be a culprit to your problem.
Old Nov 28, 2004
bzrollin's Avatar
bzrollin is an unknown quantity at this point
I'd sub in another set of rca's and see if that will solve your problem - the few times i've run across a problem like that its been a damaged rca cable.
Old Dec 14, 2004
wass86's Avatar
wass86 is an unknown quantity at this point
Angry Exact same problem....
[SIZE=7]I'v got the exact same problem, whining noise out of the front passanger speaker, even when the volume is low. I have a Apline 7894, standard speakers. I get this noise even when the volume is at 0.
Old Dec 14, 2004
es2's Avatar
es2
bubble party!!!
es2 can only hope to improve
same problem here,(mine is in the passenger side too)
i have memphis audio class d speakers
Old Dec 14, 2004
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
Turn your air on and see if there is a whinning noise. Now turn it off and if it only little now then just ran a new wire. thats what i did.
Old Dec 14, 2004
es2's Avatar
es2
bubble party!!!
when i turn my air on, it gets louder, or when i roll down the windows
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
