Any tips on getting HU installed?
Old Oct 14, 2004
IronFist's Avatar
I'm making an appointment to get my new HU installed after work today. Is there anything I should know or be careful of that Circuit City might try to pull on me? Think they'd let me watch if I asked? I already went through the box to see everything that it comes with so they can't not give me something and then claim it wasn't there, like the tried to do with the remote bass control that came with my amp
Old Oct 14, 2004
7thGENDMAN's Avatar
7thGENDMAN is on a distinguished road
Do you have the wiring harness and dash kit?? If you do, I will put it in for you at the show this weekend. Pretty easy install! What kind of HU is it. They do make what they call "smart wires", which require NO soldering or crimping. Real simple.
Old Oct 14, 2004
4Saris's Avatar
4Saris is an unknown quantity at this point
-Request that they solder the connections not crimp them.
-Don't let them tell you that you need an antenna adapter like they did my wife.
-Make sure that they connect the power antenna or else you will get sorry FM and AM reception (Yellow/green wire on the vehicle's harness is the power antenna wire. They will need to hook a wire from the yellow/green to the blue wire on the head unit.)
-Check all the plastic panels for integrity so that they did not lose the clips and break the plastic ones.
Old Oct 14, 2004
Um yeah. We have a meet this Sat. I'm sure someone knows how to install a deck for you
Old Oct 14, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
circuit city? let one of your fellow 7thgens do it for you.
Old Oct 14, 2004
IronFist's Avatar
Guys I think I'm working this weekend
Old Oct 14, 2004
7thGENDMAN's Avatar
30 minutes tops!!! Let me know, I'll do it cheap. How much did CC want for the install??
Old Oct 14, 2004
IronFist's Avatar
um $45 plus some parts but I already have the parts.
Old Oct 14, 2004
MegaHurtz's Avatar
This is an awesome DIY if you are so inclined to do it yourself. All you will need is a phillips head screwdriver, an 8mm socket and ratchet, a pair of crimpers (a stripper/crimper/etc combo works best) and approx 16 butt connectors.
Old Oct 15, 2004
hman913's Avatar
hman913 is an unknown quantity at this point
About the DIY... Crutchfield.com says that they include instructions for HU installs. How good/thorough are these instructions?
Old Oct 15, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
they are decent - but the install isn't as hard as you'd think. Wiring is they key thing.
Old Oct 15, 2004
takumi's Avatar
takumi is on a distinguished road
CC installed my HU free when I bought it. It looks like they did an OK job but they scratched up my car a lil
Old Oct 15, 2004
they broke my shifter trim but ordered me a new one
Old Oct 16, 2004
hman913's Avatar
Wiring is the biggest thing I'm worried about. Between circuit city and best buy, who would be the best to go with?
Old Oct 16, 2004
circuit city solders connections I believe and does a better job overall. But the installers vary from store to store. I've heard horror stories about best buy.
Old Oct 16, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Head unit wiring is simple, thats NOT what I'd be worried about. I'd be mroe inclined to go where I thought they would show more care and concern about my interior. Civics, being that you have to take apart the interior more than a lot of other cars to access the headunit are tougher than some cars to take apart without damaging things. The plastic and vinyl used in our cars is brittle and impressionable respectively. I would consider whos less likely to damage my interior when deciding. Any jackass can wire the deck, but will that jackass resist the temptation to pry off the trim pieces with a pry bar??
Old Oct 16, 2004
IronFist's Avatar
CC is better than Best Buy. Their selection is a lot better, too, altho for some reason they're not going to carry Alpine anymore in a few months, so maybe not.
Old Oct 17, 2004
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Originally Posted by IronFist
... altho for some reason they're not going to carry Alpine anymore in a few months, so maybe not.
That because Best Buy is picking them up, just like Viper.
Old Oct 17, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
yep wiring is a bitch but all you really have to do is match up the wire colors and connect them.
JohnnyBxo
Nov 12, 2015 03:04 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
