sub death (maybe)
Old Oct 5, 2004
Ice_Man's Avatar
Ice_Man is an unknown quantity at this point
sub death (maybe)
So... yesterday I was transitioning from Evanescence to Michael Jackson, and as the first notes of Bad begin emenating from my system, I realize I have no bass. Seconds into the song, I hear a moderate thump followed by more silence from my trunk.
I know my amp has power and that all fuses involved are still good. I need to test the:
- Preouts on my head unit (Pioneer 7600)
- Pre-out cables
- Input stage on the amp
- Output stage on the amp
- The sub itself
I get no sound/noise/anything from the subwoofer which makes me wonder if it is blown or if it is just getting no signal. What is the best way to test a pre-out level signal? This wasn't even a super-hot Arizona day, just moderately high temperatures, so I'm hesitant to say anything overheated unless a short was involved.
Two Nightwish CDs on the way from Amazon and no bass...
Old Oct 5, 2004
IronFist's Avatar
Hell yeah dude I just saw Nightwish in Chicago at the House of Blues last month
Sorry, I know this doesn't help your problem, but I just think it's awesome that there's another Nighwish fan on the board.
Old Oct 5, 2004
MegaHurtz's Avatar
See my comments in red
Play a continous sine wave over and over at say... 80hz or lower through your CD player with your back speakers disconnected and the head unit faded all the way to the back (no point in playing it thru your speakers). You need to make a short RCA cable with a single male end and make it so the other end has the wires stripped and can be hooked up to a Digital Multimeter (DMM). Set the range on the DMM to the 200v AC and connect the RCA contraption to the outputs. With the volume up and the sine wave playing you will get a reading on the DMM. You really only need to test the preouts that are giving you trouble and you can only check one channel at a time. If you are using both channels on a pair of preouts, you need to check them both individually.
- Pre-out cables
Get a barrel jack (female/female RCA adaptor), plug both the RCA contraption and the RCA cable into it and test for signal again, using the same process that I described above. Make sure the RCA cable is plugged into the head unit you will need signal going through it to test. Note if there is a SIGNIFICANT voltage drop.
Hook a working speaker up and test at low volume. If sound comes out the input stage is working. Or if it doesn't work, try either A) checking the amp's RCA outputs assuming it has them which I imagine it would or B) open the amp and check the PCB
Hook a known working speaker up and put volume to it.
- The sub itself
Remove from the box and check for damage. First thing to check is the tinsel leads which are the silver wires going from the terminals to the voice coil. If it is bad you will know because it will be physically broken, probably at the terminal. Next, smell the sub very closely all over. If you know what burnt voice coils or electronics smell like you will be able to identify it fairly easily. Next, push down even and ever so slightly on the cone. Try to identify if the sub does not want to move up and down or if you get bad noises when you move it. Check for other physical damage. Get a DMM that can check for continuity and hook it up to the + and - speaker leads. If you press down and it has no continuity the subs is toast the voice coils are bad.
That's about all I am physically capable of thinking of so good luck.
poiuytrewq
Old Oct 5, 2004
Ice_Man's Avatar
THANK YOU! MegaHurtz
I'm going get my boss to lend me an oscilloscope from work. That way I'll be able to tell if I have any low voltage shorts along the RCA's. Also useful for seeing how much noise I have in my power lines.
Old Oct 6, 2004
MegaHurtz's Avatar
You don't need an Oscope you need a digital multimeter
Old Oct 6, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
its blown
Old Oct 6, 2004
MegaHurtz's Avatar
Why do you say that?
Old Oct 6, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
You know mega has done some of his finest work when he closes with
poiuytrewq. Which BTW, I can't beleive you've replicated the same word from before. HA, at least you'll find the post again
Old Oct 6, 2004
Ice_Man's Avatar
I know I don't need an oscilloscope, I just think it will be fun.
Not that I don't appreciate the simple solution, i.e. what I did last night which was strip an old pair of broken down 8 Ohm headphones and stick them on the speaker-out of the amp. Ozzy sounds quite flaccid through such speakers.
Anyway, the sub is obviously broken. No continuity across the coils.
Good excuse to upgrade
Old Oct 6, 2004
MegaHurtz's Avatar
But correct me if I am wrong, you can't check voltage level with an Oscope?
Old Oct 6, 2004
MegaHurtz's Avatar
Try plugging the sub into the wall and take a video if it does anything
Old Oct 6, 2004
Ice_Man's Avatar
DC will read flatline on an oscilloscope, but biased off of ground according to how much DC voltage is being read. Since it plots voltage over time any significant noise will be visible on the oscilloscope if the display is scaled properly.
Haha let's see... 60 Hz, 120 V, 4 Ohms... 3600 Wrms. There might be some pretty sparks.
Old Oct 11, 2004
Ice_Man's Avatar
Diagnosed and fixed
One of the voice coils on my sub was open-circuited. Happily, no damage to the amp. It took forever to get the new sub to seal to the enclosure. Kept whistling and such. Eventually I resurfaced the wood and torqued the screws down with a power drill to get it to seal.
Thanks again for the input.
Old Oct 11, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
Dude It's the top row of your keyboard backwards, poiuytrewq OR qwertyuiop
Old Oct 11, 2004
MegaHurtz's Avatar
yeah I know... I use it when I make a useful post so that I can find it again easily if I need to, i use it as a search keyword
LilNic13
Nov 28, 2015 10:26 AM
speedlever
Sep 24, 2015 07:18 PM
JetsterDajet
Aug 15, 2015 08:07 AM
