Install tip for dynomatting
Old Oct 2, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I have always hated the sealant that Honda uses on the moisture barrier on the door. Its far more sticky, stringy and just plain nasty as other manufacturers'. Today I tried something other than razor blades, plastic scrapers and solvent. Today I put a strip of duct tape over the gooey mess still on the door, used my roller to roll it on and then pulled it of taking with it the majority of the evil white messy sealant - similar to how your grandma waxes her lip. Just passing on a good tip that worked well for me.
Jason
Old Oct 2, 2004
Where were you when I dynamatted all my doors and had to rub it with goo-gone for hours?
Old Oct 2, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Why didnt you just leave it on there? I did....
Old Oct 2, 2004
J187's Avatar
Gear, I was probably rubbing my door with prep-sol for hours. LOL.
Mystic, because technically it interferes with the adhesion of the dynomat and I am unfortunately, a perfectionist.
Jason
Old Oct 3, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Aircraft stripper works too. Least it did for me. Just be careful when applying it, as it'll mess your paint up if you get it elsewhere.
Old Oct 3, 2004
Mystic3030's Avatar
Jason
Technically it would add extra damping ability....not much, but it would.
Old Oct 3, 2004
J187's Avatar
Ok, but it still interferes slightly with adhesion. The dynomat doesn't stick to the stuff.
Old Oct 3, 2004
zen_master's Avatar
hm, case to explain what u did?
Old Oct 3, 2004
J187's Avatar
Do you mean what I did about the nasty sealant? If that was your question, its the start of this thread scroll up. If that wasn't your question I guess I missed the question.
JohnnyBxo
Nov 12, 2015 03:04 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
