Amp install
Old Sep 20, 2004
angelswin's Avatar
angelswin is on a distinguished road
Amp install
I want to re-install my amp in my trunk and I have an idea how i want to do it.Right now its just sitting on the floor but what I want to do is hang it from the metal near the speakers to get it off the floor.Does anyone have any idea what kind of brackets I could use or how I would do this?
Old Sep 20, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
got to home depot and buy the 2" alluminum flat bar, they're selling it for about 4bucks a pop for 4' but I bought the 1" one and I can virtually use it for anything... easy to bend too...
though you have to reconsider that there's a metal spring that holds the trunks weight... convert your trunk spring to shocks then mounting your amp to the metal would be possible search on thread or DIY "trunk shocks installation"
Old Sep 20, 2004
MegaHurtz's Avatar
Bad idea, that will prevent the amp from cooling properly and your amp could overheat or worse...
Maybe build a panel on the side of the trunk and mount the amp on there? Just a thought...
Old Sep 20, 2004
brash's Avatar
brash is an unknown quantity at this point
Yeah, you don't want to mount your amp upside down, especially with no air above it. The heat will just accumulate...
Unless you are planning on putting a fan in there, too. In which case it might be ok.
Old Sep 21, 2004
civic2nr819's Avatar
civic2nr819 is an unknown quantity at this point
you wouldn't want to mount it on metal for heat reasons and you might short out since the metal is connected to the chassis of the car and that is the ground.
Old Sep 21, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
why not mount it on the back of your seat...buy some plywood to slide underneath the carpet and then mount the amp there
Old Sep 27, 2004
angelswin's Avatar
O.K. What I did is I bought some metal pipeand secured it from the frame of the car where the speakers are.On the medal pipes I slapped a small piece of carpeted mdf.So now its hanging from the frame so it looks like its sitting in mid air with the back end a little higher than the front.
Old Sep 27, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Got any pictures. Sounds interesting. I'd like to see how it came out.
Old Sep 28, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
time to post pics so we can see. Sounds interesting is right!
Old Sep 29, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
Instead of MDF you could use some plexiglass and mount the amp on that . . . then it would REALLY look like it was floating. A shop here in Austin did that to an SUV and it looks awesome
Back on topic, you really don't want to mount your amp upside down.
OptimisticWay
46
Oct 15, 2015 02:16 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
