Aftermarket HU & Antenna
Old Sep 6, 2004
thejdog's Avatar
thejdog is an unknown quantity at this point
I bought a Alpine CDA-9825 a while back, in Feb. Since I've installed it, I've never had any Antenna reception. My car is a 2003 Honda Civic LX, with the Antenna built into the window. I wouldn't think that there is a power antenna connector for it. But the antenna connection is in there.
Is there a power antenna connector I must conect to? I've looked over all the wiring I've done and it looks fine, and not a big deal, I'd just like to have radio every once in a while, incase I forget my CD's or something.
Thanks in advance!
Old Sep 6, 2004
Ed's Avatar
Ed
There should have been a wire that needs to be plugged into the back of the HU. Not part of the harness, but a separate plug.
Old Sep 6, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Might also want to check the power antenna wire. There's some threads on here about it.
Old Sep 6, 2004
MegaHurtz's Avatar
From what I've gathered so far, the power antenna doesn't work with aftermarket HU's, so you need to tap a switched power source into the power antenna power to make it work
WHY the power antenna doesn't work with aftermarket HU I do not know, but apparently it doesn't.
Check the factory plug and see if there are any pins that are not on the aftermarket harness
Old Sep 6, 2004
thejdog's Avatar
Well, I looked at all the wires that go to the stereo and there are none that have been left un hook to another wire. The only wire's that aren't actually connected to anything is the dimmer wire, because I don't have one on my Alpine HU.
Would it be a power antenna, because it is in the window, I believe, I can't seem to find it anywhere else.
Another thing, is I could first turn on the car and it'll work for a few minutes, but after a few minutes, it just goes all static.
jDoG
Old Sep 7, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Yellow/green wire on the vehicle's harness is the power antenna wire. Works fine using the power antenna lead from the head unit, but is not on any current adapter harnesses.
Hook a wire from the yellow/green to the blue wire on the head unit.
Old Sep 7, 2004
thejdog's Avatar
So splice the Yellow/Green adapter from the original Honda wiring and connect it to the Blue wire? Now blue I believe is the remote on for my Amps, but that still make work!
jDoG
Old Sep 7, 2004
MegaHurtz's Avatar
Yeah the yellow/green is probably a turn on lead for the powered antenna
Old Sep 7, 2004
Even though the antenna is in the back window, there's still a power antenna wire.
Old Sep 7, 2004
MegaHurtz's Avatar
it's a powerED antenna as opposed to a power antenna
that would kind of confuse some of us a bit
Old Sep 7, 2004
thejdog's Avatar
But the only color my connecto has on the back of the head unit is a blue/white wire not a plain blue wire, and the blue/white wire is the remote on!
jDoG
Old Sep 7, 2004
MegaHurtz's Avatar
thats fine... as long as it's the remote wire, you can just connect it to the yellow/green
Old Sep 7, 2004
thejdog's Avatar
Well, here we go agian, let's see if this works!
jDoG
Old Sep 7, 2004
thejdog's Avatar
After taking my head unit out today & yesterday, I still can't find the correct wire.
THe bule/yellow looks like the speaker connection on the honda!
jDoG
Old Sep 8, 2004
thejdog's Avatar
the yellow/blue wire is for a certian speaker!
jDoG
Old Sep 8, 2004
tom1178's Avatar
tom1178 is an unknown quantity at this point
Make sure you are looking for the yellow/green wire that comes from the original car harness.....trace back as far as you can visually see where the wires behind your head unit come from....you'll find the yellow/green one
Old Sep 8, 2004
JDMVTECB20's Avatar
JDMVTECB20 is an unknown quantity at this point
my g/fs car had an extra antenna on the front windshield, that one was powered. It seems like the powered ones do get better reception.
Old Sep 9, 2004
thejdog's Avatar
Hmmm
jDoG
Old Sep 9, 2004
MegaHurtz's Avatar
I say find a switched wire and splice it in at the antenna not at the back of the deck, it might be a lot easier
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
beanhead
Sep 24, 2015 12:04 PM
bhollie
Sep 22, 2015 11:08 PM
ZoSoIV
Sep 17, 2015 07:17 PM
