Details on changing battery
Old Sep 5, 2004
MegaHurtz's Avatar
For those who put a larger battery in their vic, can you give me the specific details of what you had to do to get it in?
The more specific the better
Old Sep 5, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I put in a standard sized (I believe it's group 74) Optima Red top. To install it, here's what I did.
1. Remove old battery and battery cover.
2. Unscrewed the stock tie down almost all the way out (had to unscrew all the way on one side to remove stock attery).
3. Placed Optima in stock battery tray (not using the cheapy battery cover).
4. Put stock tiedown back in place and began tightening the wing nut/screw that was removed completely to take out stock battery.
5. Alternated tightening both sides of tie down until hand tight.
6. Cinched the screws down snug with tools.
7. Connected ground then positive back to battery.
8. Enjoyed much improved battery.
Old Sep 5, 2004
MegaHurtz's Avatar
HA I just finished, it was so easy, I don't know what I was so concerned about.
Easy mod and i am expecting great results
Old Sep 5, 2004
MegaHurtz's Avatar
For those interested, here is how it looks...
The battery, an Exide Extreme Cycle Duty BCI# 34/78 Part# 34XCD
Phoenix Gold 140 amp circuit breaker mounted on the side of my air box with velcro
Battery and circuit breaker in the same pic along with the rest of my engine
Old Sep 5, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
2 comments. First, it would have been cooler to use two different colors of wire loom so you can tell positive from negitive. Second , the glue on the velcro backing will probably deteriorate with the heat of the engine compartment so you may want to think of another way to fasten it.
Of course take this coment with a grain of salt since I haven't upgraded my wiring yet. Also thanks to your post I now have in my head of using two different colored wire loom I was just going to use straight black for both but yours looked cool so I have to do colored loom now
Old Sep 5, 2004
LudlamTheory's Avatar
i boogie for the raindrops
mine's bigger than yours =P
of course mine required modification of the tie down, chopping out a piece of metal, and rerouting some stock wires over to one side, so it was kind of a pain in the ***
Old Sep 5, 2004
oh, and removing the last part of the stock intake
Old Sep 5, 2004
MegaHurtz's Avatar
Damn man what are you running?
Old Sep 5, 2004
MegaHurtz's Avatar
I wasn't really going for any cool look on the wire loom I just wanted some color in my engine bay. It's not much for show (except SPL), but I just wanted to brighten things up a bit...
The glue on the velcro shouldnt come off, this stuff is like super industrial. It's not conventional velcro, it appears to be some new kind of velcro that holds really good and has super duper glue on the back
I still haven't touched any of the other wiring, all my grounds are stock and my alternator to battery wire is obviously still stock. I have considered doing them I just think the results may be questionable
Old Sep 5, 2004
Ludlam... Simple Green mang... works like a charm LOL
Old Sep 6, 2004
whats simple green
Old Sep 6, 2004
A cleaning solution...
Old Sep 6, 2004
MegaHurtz's Avatar
HAHHAHAA
Old Sep 6, 2004
Ed's Avatar
Ed
Hahaha
Old Sep 6, 2004
man, unless itll make my stereo sound better, theres no need for cleaning
Old Sep 6, 2004
fonto's Avatar
The LA Clipper
Old Sep 6, 2004
MegaHurtz's Avatar
I guess not everybody has a problem with riding in filth
Old Sep 6, 2004
i dont know how often you ride in the engine compartment man, but i prefer the drivers seat
Old Sep 6, 2004
I was just bustin your *****. Don't know bout anyone else.
Old Sep 6, 2004
MegaHurtz's Avatar
well on cold days a good ride in the engine compartment will warm you right up
Old Sep 6, 2004
Silver_JS5's Avatar
Silver_JS5 is an unknown quantity at this point
so what's the point of running a bigger battery? what will that do for you? Just curious
Old Sep 6, 2004
MegaHurtz's Avatar
I want the reserve capacity so I can compete with my car off in order to follow the dB drag rules. The stock battery is so tiny that after the first burp there is not enough juice left to bring up the numbers. Also, this battery is deep cycle so I can kill it and charge it a lot more before it starts to break down.
This particular battery is designed for audio systems and heavy electrical loads so it should improve performance in general
Old Sep 6, 2004
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
But MegaHurtz probably cost 100 bux more! Haha it;s a spiral cell that's sold for like 160CDN. Crazy crazy
Old Sep 6, 2004
MegaHurtz's Avatar
Actually it's 180 but who's keeping track?
I'm sure Ludlam's cost a pretty penny as well, just because of the sheer size alone
Old Sep 6, 2004
joski's Avatar
Nah I just used to work for Crappy Tire so I sold those batteries.. You spent your money well is all.. Hah
Looks good BTW!
Old Sep 7, 2004
MegaHurtz's Avatar
Thanks and I paid $150 for mine
No tax
Old Sep 7, 2004
MegaHurtz's Avatar
Y'all think I should fix that wire that is running over my air intake to the circuit breaker?
I'm thinkin I should make it a bit longer so I can take it under the intake and make it a bit cleaner
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
Grey
16
Jan 27, 2002 11:34 PM
2k2civic
Dec 6, 2001 09:41 AM
