Best Head Unit for your money
Old Sep 3, 2004
Rx7_Fan's Avatar
Rx7_Fan has a little shameless behaviour in the past
Hey guys,
Just wondering on your opinion on the best Alpine head unit for your money. In other words, the best 'bang for your bucks' I'm thinking of the alpine 9833 or 9831 the only difference I see between the two models is the watts per channel. the 9831 is like $60 bucks cheaper, So i was wondering if I should get the 9831 instead of the 9833. Ooh, if you guys recommend different mondels, please let me know.
I greately appreciate any contructive/positive feedbacks.
Old Sep 3, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
9833 has 6 channel time correction versus 4 channel on the 9831, it has a 6 position active crossover with a variable 24 db slope, whereas the 9831 has a 3 position crossover with no slope adjustment
9833 has the ability to go into "pro" mode and act as a passive crossover for your entire system, allowing you to remove the crossovers on your components.
9833 has a 5 band parametric EQ, 9831 has "bass" and "treble"
The full specs are available at www.alpine-usa.com
There are quite a few differences between the two!
Old Sep 3, 2004
Rx7_Fan's Avatar
seems to make just the 5 band parametric EQ makes it worth it to buy the 9833 rather than the 9831. You guys think intallation will be hard since it has the v-drive thing?
Old Sep 3, 2004
MegaHurtz's Avatar
please enlighten me, what is v-drive?
Old Sep 3, 2004
Mystic3030's Avatar
CEA spec amplifier inside...the wattage advertised gives peak and RMS out of the HU instead of just peak.
Old Sep 4, 2004
faultyscrew's Avatar
faultyscrew is an unknown quantity at this point
Definately! Get as much EQ you can get - a bass and treble EQ will not satisfy your music, or your ears - trust me
Old Sep 4, 2004
Mystic3030's Avatar
Installation is also the same with the v-drive...its just the internals of the HU that are different. Don't worry about it.
Old Sep 7, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Also, the 9833 can be set to perfectly match the display of the gauge cluster in most cars due to its 512 color tuning display
Old Sep 7, 2004
Rx7_Fan's Avatar
I've been reading that the antena doesn't work with after market HU, is this true? I hope not or it would suck! I want readio =)
4 banger
Jun 5, 2015 01:44 AM
mugenca
Apr 16, 2015 12:15 AM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
ACEM2
Dec 22, 2001 09:14 PM
