sensitivity
Old Aug 27, 2004
Adamb123's Avatar
Adamb123 is an unknown quantity at this point
sensitivity
Hey how do I increase the sensitivity (making my alarm more sensitive) of my viper 671xv.
Old Aug 27, 2004
kalipnoi's Avatar
kalipnoi can only hope to improve
i think there is a clear little unit that is pluged into the alarms brain. you should see a part where you can use a philips screw driver to tighten or loosen. i think that will increase.
Old Aug 27, 2004
Adamb123's Avatar
I found that piece. However, I tried making it more sensitive and it did not seem to work.
Old Aug 28, 2004
kalipnoi's Avatar
try going to a local audio or car alarm place. they should be able to help you. most of the time they won't even charge you to do something so small, but try and go back to the place you got it installed and let them know that they installed it.
Old Aug 28, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
be careful about making it more sensitive, you probably want to show to all your friends it chirps as you touch it which is great in an empty parking lot. Park downtown and prepare for every bus and truck to set off that alarm.
A good alarm will, sound immidiatly upon window breaking, will sound completly when somone trys to open the doors, and gives warn away for gentle taps.
Old Aug 28, 2004
Adamb123's Avatar
I understand Adam, thanks. Yea, the problem is that my alarm doesnt even give a warning chirp when I shake the car.
Old Aug 31, 2004
WhiteRabbit's Avatar
itll do that naturally. it senses sudden movements, not gentle ones. so shaking the car should be pretty fine. give teh car a good tap with your open hand (somewhere that wont dent easily) and the alarm should go off.
if it doesnt, turn the adjusting screw the other way
italginny
Jun 8, 2003 12:24 AM
UltraLaser
Jan 31, 2003 11:37 AM
FlippedOut
Aug 28, 2002 07:09 PM
