HELP, AMP wiring that woudn't get me ENGINE NOISE!
Old Aug 26, 2004
tgctruly's Avatar
tgctruly is an unknown quantity at this point
Talking HELP, AMP wiring that woudn't get me ENGINE NOISE!
I am installing an amp/component speaker/headunit right now, thank you for all you buddies support i appreciate it.
Now, I have another question about running the wires for amp, I know that amp's RCA and Power wires need to be seperate to avoid engine noise. How about remote wire and the speaker wires hooking on the crossover?
Now, I go RCA/14 gauge speaker wire hooking on crossover/remote wire all on 1 bundle in center, and power wire all alone at passenger side.
I want to know if my wiring is in good shape and not getting engine noise by that. Or you guys suggest in different way such as RCA/SPEAKER WIRE 1side, remote/power the other?
TKS!!
Old Aug 26, 2004
MegaHurtz's Avatar
That looks pretty good
Remote wire is very small to put any noise into your system, but it definitely would not hurt to run it alongside your power wire. The way it is though it should not cause any problems
Old Aug 26, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I agree ^
I laugh at those RCAs you can buy where it has the rcas and the remote wire all in a bunch so you don't have to run the remote wire seperate but still.. convienent, yes.. Logical, no. Pretty much nothing noticeable to the ear but it might show up on an oscilloscope. ha I might have to check that out at work sometime.
Old Aug 27, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
if u get serious engine whine... it might be ur deck. I ran a 4 ch with a JVC deck... MAJOR engine whine, switched it with a pioneer and had little to none. Added some ground loops and it was all clear. So check ur wiring, your deck and add ground loops if you need it.
Old Aug 27, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
refer to ur other post.
buy rca w/ built-in remote lead...knukonceptz.com awesome site for installation accessories.
Old Feb 1, 2005
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
dude if you getting a engine whine, you ground isnt really grounding.. Scrape of some paint where ever your ground is and it will take care of the whine.
Old Feb 1, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
In civics, I find that other than the ground, a lot of engine whine comes from RCAs behind the HU. 1st You should recheck all grounds. Then check for breeches in RCAs.
Old Feb 1, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
If possible, shield your RCA's where they come out of the Head unit. I'd shield it at least 2 feet. Then, make sure you make a seperate run from any current carrying wire. Like run the RCA's down the driver's side, and power/remote down the passenger side. Or, one down the side, and one down the center. Keep them seperate and you should be all good.
Old Feb 1, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
what brand of amp? When I did my install in 2K3, my four channel Poweracoustik ended up being the culprint for the engine noise - upgrading to an Alpine MVR-F340 was the fix.
Cheaper brands of amps simply don't have as good noise reduction circuity as higher end amps do. Your other option is to use power line or RCA filters. Pros here wil poo-poo it but if you need a cheap fix - rad shack RCA ground loop filters served me well through 3 installs.
Old Feb 1, 2005
Who brought this post back? THis thing is oooooold.
Jon-Ohio
Jun 30, 2018 08:10 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
PimpBot5000
Nov 26, 2001 07:15 PM
