Auxiliary input with blue backlighting
Old Aug 20, 2004
RFnoyz's Avatar
RFnoyz is an unknown quantity at this point
Hey all! I just added an auxiliary input (Logjam/PIE part #HON98-AUX) to my 2003 Civic so I could listen to tapes and MP3s. My addition was that I put a blue backlight on the jack, which serves a few purposes:
- I can find the stereo jack in the dark
- it indicates whether the jack is grounded to the car or not (via the switch)
- it looks cool!
- it lights up my drinks at night
So whaddaya think? If anyone's interested, I'd be happy to post some instructions.
ID:	36494   Click image for larger version
ID:	36495   Click image for larger version
Old Aug 20, 2004
teampointless's Avatar
Ultimate Member
doesn't look too bad...
Old Aug 20, 2004
MegaHurtz's Avatar
Pretty nice, make a DIY on it, we get lots of questions in here about doing an aux in
Old Aug 21, 2004
eni9ma's Avatar
eni9ma is an unknown quantity at this point
Is this what you bought?
http://www.logjamelectronics.com/piehon98aux.html
It looks like its just plug and play, can you confirm that? I am also interested in doing this mod. Thanks in advance. Oh yea good job dude
Old Aug 21, 2004
Now all you gotta do is change the dash lights to blue so they match the cluster Looks good tho.
Old Aug 23, 2004
RFnoyz's Avatar
Thanks! Yeah, that's the input that I used (the PIE HON98-AUX). It was very easy, totally plug and play. Two quick points though:
1. They mean it when they talk about grounding issues. If the ground isn't set up right, the noise overwhelms the music signal (not just a little static).
2. For my 2003 Sedan, I had to use the 2004 instructions (found here: http://www.handa-accessories.com/civic/04cdcass.pdf ) in order to get to the back of the stereo. Everything came apart with 4 screws and a bunch of panel clips. If I had followed the 2003 instructions, I would have done some damage...
Everything else is cake- the little panel covers pop out easily, and you can mount the connections right there (or you could run the wires through to the center console).
I'll try to get my act together to post a DIY describing the aux input and how the backlight works.
Old Aug 23, 2004
eni9ma's Avatar
Awesome! Thanks man.
Old Aug 25, 2004
es2k2's Avatar
Proud to be a civic owner
where did you get the glow in the dark stereo jack from?
Old Aug 26, 2004
RFnoyz's Avatar
I made the backlit stereo jack- I glued a regular panel-mount stereo jack into a machined acrylic housing. The acrylic piece has some white paint on the back to diffuse the light coming from a blue LED that is located behind the little panel cover.
I'll try to post a DIY (with drawings) on both the auxiliary input and the backlight, but it won't be for a few weeks. I think there is a way to do the backlight without needing a machine shop, but I'll have to think about it...
Old Sep 7, 2004
ry's Avatar
ry
darkness
ry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of light
anyone have a wiring diagram of this? looks like it can be done the same way as pioneer cdplayers, all you have to do is connect the pins to the correct pins on the cdchanger input and you just saved 50 bucks
Old Sep 7, 2004
savedadogs's Avatar
savedadogs is an unknown quantity at this point
Cool, I thought I had to buy an aftermarket radio just to get the aux in. Can you make a DIY?
raymondxcho
Sep 29, 2015 09:00 PM
Luluharp
Sep 27, 2015 11:56 AM
speedlever
Sep 24, 2015 07:18 PM
JMKendrick
Sep 16, 2015 06:17 PM
MamaBear2015
Sep 4, 2015 09:04 PM
