set voltage to trigger a circuit?
Old Aug 2, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
ya know shiftlights' circuitry are based on a set voltage level that will trigger the light, right? (it takes a certain amount of electricity to make the light turn on).
anyting i could get at radioshack that would let me do this? im doin a project for school and it requires this. thanks!
Old Aug 2, 2004
Ed's Avatar
Ed
What voltage are you looking for?
Old Aug 2, 2004
skarteez's Avatar
ill find that out once i get a multimeter and tap the tach wire
but for now, what are the circuit components called that allow this kind of circuit tobe built?
Old Aug 2, 2004
Ed's Avatar
Ed
http://www.discovercircuits.com/PDF-FILES/voltst1.pdf theres one, it's more compliccated than you need though, it measures whether the voltage is high, low, or acceptable. I'm thinking an easy way to do this would be to figure out what voltage you need to measure, then use LEDs that turn on at the proper voltage
jnissen
Aug 9, 2015 05:34 PM
jzhartman
22
Jul 23, 2015 10:42 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
Jul 12, 2015 11:54 AM
