Problem with Power Windows...
Old Jul 22, 2004
Al_ics's Avatar
Al_ics is an unknown quantity at this point
Okay so heres the problem...
I installed a power windows kit about 3 months ago...no problems has occured until today...
-->I have blown two fuses today...
Also i installed a DIY grounding kit about 3 weeks ago...
-->Is this a possible cause??
Can anyone please tell me what to look for??
thanks
Old Jul 22, 2004
Al_ics's Avatar
****...make that 3 fuses...
Old Jul 22, 2004
MegaHurtz's Avatar
When does the fuse popping occur?
Old Jul 22, 2004
Al_ics's Avatar
good question...
On the second fuse--> the fuse blew when i pushed on the switch
Third Fuse--> It popped when i put on the car...
Old Jul 22, 2004
MegaHurtz's Avatar
and the first?
Old Jul 22, 2004
MegaHurtz's Avatar
the problem is probably a short created when you hit the switch. Check ALL wire connections at ALL points. Make usre nothing is touching, if you can, trace every wire and make sure nothing is pinched and causing a short somewhere.
Old Jul 22, 2004
Al_ics's Avatar
the first must have been this morning...
either when i put on the car or when i touched the switch...i cant remember...
Old Jul 22, 2004
MegaHurtz's Avatar
Does it do it when you try to roll down the passenger side window as well?
Old Jul 22, 2004
Al_ics's Avatar
yea....that was on the second fuse...it blew when i put down the passenger side down
Old Jul 22, 2004
MegaHurtz's Avatar
What abotu the driver side?
Old Jul 22, 2004
Al_ics's Avatar
it was fine, until the third fuse--> which blew rite when i started the car..
could it be the power source?? im tapping the white/red wire...
Old Jul 22, 2004
MegaHurtz's Avatar
What fuse is blowing? You didn't add a new fuse when you installed the kit?
Did you have to manually run any wires through your doors?
Does it blow fuses for BOTH the passenger side and drivers side?
Old Jul 22, 2004
Al_ics's Avatar
theres only one fuse in the kit...its connected to the power source...
and yes i did have to manually run wires through the door jamb...
RITE now it blows when i put on the car...i'm running out of fuses
Old Jul 22, 2004
MegaHurtz's Avatar
Open the doors and try again
Is the fuse after the tap (on the aftermarket wiring), or before (touching stock wiring)
Old Jul 22, 2004
Al_ics's Avatar
the fuse is before the stock wiring...
Old Jul 22, 2004
MegaHurtz's Avatar
Add me on MSN, rollz2low_420@hotmail.com
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
Ronin
Apr 18, 2002 10:14 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
