hi everyone, i just ordered http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT off of ebay. and i have a couple questions. first it didnt come with a bass remote, without it is there any way i can turn the bass up? (it is powering 2 polk 10's) what is the bass output now without the remote on it? and how would i bridge it to both subs? thanx ~nick
That's a nice little amp, but not to rag on you but that amp is not meant for subs, it is meant for powering 2 midrange or high channels.
Where does it say that it doesn't come with a remote bass?
If your subs are 8 ohm each (assuming they are only SVC), you can wire them in parallel (+ to +, - to -) and then bridge your amp to run in mono pushing both your subs.
If you are using 4 ohm or another voice coil configuration, you might not be able to bridge the amp.
