cd won't completely insert
Old Jul 11, 2004
higgie's Avatar
higgie is an unknown quantity at this point
bought a stock honda cd/am/fm head unit on ebay and the cd won't completely insert. motor only pulls it in partially. any easy tricks on how to fix this before i pull it out and send it back?
Old Jul 11, 2004
higgie's Avatar
just popped the stereo out. i am getting better, it took 20 minutes. the first time i tried, it took over an hour (had to figure out what sockets to use). hopefully the third and last time will be the fastest.
Old Jul 11, 2004
LudlamTheory's Avatar
i boogie for the raindrops
well see, this is a case of leaky gears. the motors controlling the cd insertation have sprung a leak ccausing the momentum to die down when they put pressure thereby leaking.
what theyre leaking, i cant quite figure it out, but check your flux capacitor on the way out.
if all else fails let some air out of the tires
Old Jul 11, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Ignore ludlam THe unit is broken, probably why it was for sale on ebay, so you can either send it back and get a refund, or buy a new one.
Old Jul 11, 2004
DTC's Avatar
DTC
DTC is an unknown quantity at this point
The cd mech needs to be reset but in order to do that you need to tear it apart and take out the mech, easier way is to send it back or take it to a repair shop for fixin
Old Jul 11, 2004
DVnAFI's Avatar
Tiene tremendo...CULO!
DVnAFI is an unknown quantity at this point
Ill sell you mine! comes with the little compartment underneath with the little door. make me an offer. brand new, used it for 2 days then bought something else.
Causemo
Jul 4, 2015 07:11 AM
zcwagon
Apr 24, 2015 05:18 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
artychris
Nov 10, 2001 01:06 PM
