underbody rattle passenger side???
Old Jul 5, 2004
gotrice's Avatar
gotrice will become famous soon enough
hey guys, i did the diy already and everything else i've read in this forum and im getting no rattle in the trunk but underneath the passenger side im hearing a lot of rattle, like two pieces of metal of some sort. i think it may be the heat shield or something but i dont know. anybody ever experience such a problem before or know what it might be?
Old Jul 5, 2004
MegaHurtz's Avatar
Get under your car near the back, and stick your head up right on the edge of your bumper on the passenger side with the system up. Look/listen upwards and see if the sound is coming from the vent there. In my car, the vent was venting when the bass hit and I got an ugly slapping sound when the bass would drop. I haven't been under my car since then, but that stopped most of the rattle underneath my car. Whether or not there is anything else that rattles there right now I am not sure.
On my car it was on my driver side, but on yours it may be under your passenger side, or it may just sound like it is.
Old Jul 5, 2004
It may be something in the engine bay. I had a rattle in there and it sounded like it was coming from inside the car almost.
Old Jul 5, 2004
MegaHurtz's Avatar
Yeah now that you mention it I have some new rattle coming from the front of my car as well... any idea what that might be?
Old Jul 5, 2004
Check anything new you installed. My hid inverter was touching metal and rattling like crazy. So I just put some foam around it. Other things can be intakes or other parts with loose bolts. Make sure any aftermarket stuff is not touching the car body or other metallic objects.
Old Jul 5, 2004
MegaHurtz's Avatar
Nothing new under my hood ever
Old Jul 5, 2004
Or it could be the hood rattling! Mine was really bad until I adjusted those rubber stoppers. Now there's no rattle. It gets better the more you loosen them up, but then the hood lines won't match with the fenders. So don't do too much.
Old Jul 12, 2004
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
I believe he said it was coming from the rear passenger side. i don't know about your car, but i know on my car, that vent in the trunk is on the driver side. On my car I have a metal on metal rattle on the rear passenger side as well, its where my exhaust hits the stock EX sway bar. If you have an ex and an exhaust it may be that.
Old Jul 12, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
i think im hearing the same rattle, it sounds like its coming from under the car
im gonna try adjusting those rubber stoppers, otherwise i think its the exhaust
Old Jul 12, 2004
norek's Avatar
(¯`·._.·[ I.Ç.E. BÕX ]·._.·´¯)
norek is on a distinguished road
I had a rattle in the center of the car on the passenger side. It was my exhaust that was too close to the top of the underneath of the car. Go to a muffler shop or something (like Speedy) and have them heat up and move the pipe so stop the rattle if that's your problem.
My noise used to get real loud in the rain...
FYI: The noise isn't damaging your car if that's your problem.
DVexile
Jul 2, 2021 05:25 PM
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
pratik05
May 15, 2015 01:54 PM
crowtoo
May 11, 2015 06:50 PM
