Need help w/ 8 inchers
Old Jul 8, 2004
hondmatic's Avatar
hondmatic is an unknown quantity at this point
I plan on getting 1 or 2 8" Re Audio RE's. Where would be the best place to install these? Btw, I'm using these for Midbass for my front stage.
EDIT: Oops! I meant the RE's.
Old Jul 8, 2004
LudlamTheory's Avatar
i boogie for the raindrops
Originally Posted by Hondmatic
I plan on getting 1 or 2 8" Re SE's. Where would be the best place to install these? Btw, I'm using these for Midbass for my front stage.
i dont know if se's are designed for midbass situations
but if so, then instllation depends on:
1 - how much skill you (or your installer) has
2 - how much you care about stage depth and width (if you dont know what those are, then the answer is you dont care)
3 - where the rest of your speakers are installed
Old Jul 8, 2004
Ed's Avatar
Ed
If they're for the midbass for your front stage, I would assume you'd want two to keep the stereo sound.
Old Jul 9, 2004
hondmatic's Avatar
yeah....
I am going to have 2 way components in the doors(tweeter mounted by side mirror thing). I was either thinking custom kick panels for two 8s or under the seats.....but I don't think under the seats would work out to well. So I was wondering if there are any other options besides kick panels.
Old Jul 9, 2004
kickpanels would be best, but like i said, i dont know if se's are designed for midbass
better look into that more
Old Jul 9, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
you are gonna want to have your tweeter as close to the mid as possible. you should use the kick panels for your components to keep them together and try to place the 8" somewhere else. with some work, you might be able to install it in the door. disconnect the factory speakers and you should be good to go...
Old Jul 11, 2004
hondmatic's Avatar
I meant the Re's, sorry.
So my best bet would be the components in kick panels and The Re Audio Re's in the doors? I don't feel like making custom kick panels. So are their any kick panles I can buy that will fit 6.5"? Only ones I've seen for my car are these.
Broeheem
Wheels and Tires
Nov 2, 2010 11:20 PM
gearbox
53
Jun 29, 2008 10:34 PM
Blahman2
May 9, 2005 06:27 PM
Hippiboy
South Cali
Jul 21, 2003 12:51 AM
ASNG
Jul 13, 2002 01:06 AM
