Polk MM6's don't fit..
Old Jul 5, 2004
kornsined's Avatar
Unhappy Polk MM6's don't fit..
Well i just went to a professional installer and my mm6's do not fit in my factory door locations. The only way i can use them is if i get kick panels for my civic. what do you guys suggest i do? The Q logic kick panels do not fit these speakers either. any help gladly accepted.
Old Jul 5, 2004
MegaHurtz's Avatar
Why exactly do they not fit?
Old Jul 5, 2004
kornsined's Avatar
from them to not block the window they need a spacer and the panel does not fit with the spacer. So in other words the magnet is too deep.
Old Jul 5, 2004
MegaHurtz's Avatar
BS, you HAVE to use spacers (or more specifically, adapters) on our cars because of the wierd holes that the stock speakers use.
I used spacers in mine and they fit no prob, I suggest you do this job DIY.
Can u provide me with the mounting depth info on these speakers?
Old Jul 5, 2004
MegaHurtz's Avatar
After doing some research it looks like the polks have 6-3/4" diameter woofers that have a mounting depth of ~3-1/2". Rougly 1" more than my Alpine Type-S woofers that are only 2.5" deep.... maybe the MM6 just don't fit period...
You could cut and modify your door panel so that the woofers stick out a little bit and then put grills over top of them...
Just a suggestion
Old Jul 5, 2004
brash's Avatar
brash is an unknown quantity at this point
How close is the panel to fitting? You might be able to cut off the little circular plastic thing on the inside of the panel if you just need a 1/4" or so.
Old Jul 5, 2004
MegaHurtz's Avatar
Yeah u could try that
Old Jul 5, 2004
kornsined's Avatar
the installer did it's just gonna make a hole if he takes off any more. yeah these speakers are super deep over 3 inches.
Old Jul 11, 2004
kornsined's Avatar
they're in now the guy at the other location is an idiot. these mm6's sound awesome.
Old Jul 11, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
hmmmm thats weird.....how deep can it be.....i got my 6.5 infinity kappa 3-ways to fit....and the infinity its pretty deep. i used spacer, cut the door, cut the door panel to make it to fit.
Old Jul 11, 2004
LudlamTheory's Avatar
i boogie for the raindrops
my peerless csx midbasses look like miniature subwoofers, if they fit, anything fits, my spacer is almost 1.5" thick
Old Jul 11, 2004
kornsined's Avatar
it's over 3 inches deep but it was mostly the first installers mental capacity that made not fit.
intensity
May 12, 2015 10:43 PM
1028CiViC
Dec 4, 2001 09:53 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
Strychnine
Aug 15, 2001 07:07 PM
Strychnine
