Amp security
Old Jul 6, 2004
Treellama's Avatar
Treellama is an unknown quantity at this point
Amp security
Some jerk broke into my car this weekend and took my amplifier and all my toll change (but left a CD changer, head unit, subwoofer, component speakers, and the sub amplifier). I finally bought an alarm, but the guy putting it in told me what I already knew - it's only a deterent. He suggested chaining down the subs and the amps. I was wondering if anyone has tried this, and what they chain them to? Those heavy-duty bike locks are sort of what I'm thinking.
Number two, now I need to get a new amp. I had a 4 channel MTX, with about 50W x 4 (which was plenty loud enough for me). The front speakers (JL Audio components) sounded great, but the rears (Infinity Kappa 6x9s) always sounded a little muddy. I'd like to try an amp that had some crossover adjustment, because I think the bass was a little too severe, or maybe out of sync with the sub. Any suggestions?
Old Jul 6, 2004
The back seats are already locked. Just get inside and tie down the trunk lid. You can run some bike lock wire through holes in the lid and a spot below the carpet where the jack is. But first, unhook the trunk release lever so you can't open it from the front seat. It will make things much harder for thieves.
Old Jul 6, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
You could also replace your trunk floor with a sheet of 3/4 mdf. Once you do that, put some metal plates on each side where the screws will go through the floor. Drill holes in each plate, and in the mdf, run a bolt through it, and put a nut on the other side. They'll have to take out the entire trunk floor to get the amp out. to secure your subs. Unload the box. From inside the box, run a screw through the box into the trunk floor. Reload your box. They'll have to take the sub out of the box to get it out.
Old Jul 6, 2004
MegaHurtz's Avatar
What I did was make a false floor that covers my whole trunk. I have spare tire under there, and the whole thing swivels up on a hinge which is attached to a piece I made that is bolted with hex bolts to the little hump thing between the trunk and back seats.
I screwed the box to the base that it sits on from the underneath, so that it's almost impossible to get out. The amp is mounted on the side with the mounting screws under the cover plates which are held on with hex keys.
All in all very secure I think
Looks 100% stock from the outside
Old Jul 9, 2004
tacheon's Avatar
tacheon is on a distinguished road
Tamper proof torx screws to hold down the amp. =)
Old Jul 9, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Torx headed drywall screws will rip out if someone grabs an amp and yanks. Just make it so everything will take them a long time to rip out, then they just wont bother. They dont want to be sitting in your car for an extended period of time.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
