Concept for box design
Old Jul 6, 2004
MegaHurtz's Avatar
I was bored at work today so I made this concept for a sub box... let me know what you think or if you have any suggestions. The sub would be firing towards the front of the box and the magnet would be in the spot that has the most open area, if you can picture that.
Constructive opinions please
Old Jul 6, 2004
mohawkboom's Avatar
is it supposed to be a bandpass or a horn?
Old Jul 7, 2004
MegaHurtz's Avatar
Folded horn
Old Jul 7, 2004
mohawkboom's Avatar
it's not horning..it's just curving. I've played around with TQFH's for my home setup they are a serious biatch to get right. you might have to re-bult that box 4-6 times before it sounds right.. good project though
Old Jul 7, 2004
MegaHurtz's Avatar
The beauty of AutoCAD is that I only have to build once, but I can draw it as many times as I want until it looks good
Old Jul 7, 2004
mohawkboom's Avatar
Autocad plots acoustical anomolies?
Old Jul 7, 2004
Danman114's Avatar
Danman114 will become famous soon enough
http://www.bose.com/controller;jsessionid=Asij7VFxxXgB1frZgbUYLh55aLGb ZA63UfLfiA4xg1RWPljveVqi!938766629?event=VIEW_STAT IC_PAGE_EVENT&url=/learning/waveguide.jsp&pageName=/learning/index.jsp
Not that Bose is my favorite brand, but this seems similar to what you might me trying. and if you will notice that the speaker doesnt project into a "tunnel" (my word for lack of a better understanding), its the back of the speaker (magnet) that goes into the tunnel. I don't know if you have heard this little system, but it can produce some good sound, as well as get pretty loud.
good luck
Old Jul 7, 2004
LudlamTheory's Avatar
i boogie for the raindrops
good luck
no sir, bose uses transmission lines, not folded horns.
mr megahurtz, youre better off just going with more airspace and more port area if youre looking to meter higher
Old Jul 7, 2004
MegaHurtz's Avatar
Well actually I want to make something for my home theater in my room.
I wanna put the sub under my bed and get a lot of output, but right now the box I have is just a wee bit too big, and it doesn't put out that much bass either.
Short of switching to a seperately powered sub or adding a seperate amp, I wanted to see what kind of results I would get from building a better enclosure...
So if you guys think you have some better designs, let me see them. I have only 6" of height to make a box, but tons of length and width that I can use for voluem.
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
carid
Sep 28, 2015 10:13 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
