Sub and amp wiring help
Old Jul 3, 2004
Samari's Avatar
Okay, i have a question about a set up im planning on doing. I want to know if you can wire a mono amp into 2 dvc subs? I plan on getting 2 10" alpine type r subs and a mono class d alpine mrv m501 amp. The rms on the subs is 150 watts per coil and the amp is 550watts rms x1.
Right now i have 2 10" alpine type e subs and an alpine mrv t420 amp. This is forsale if anyone is interested. The subs are 600 watt peak and 50-200watt rmx and the amp is 600 watt max and 170watt rms x2.
Thanks for the help in advance.
Old Jul 5, 2004
rinsincivic's Avatar
rinsincivic is an unknown quantity at this point
just make sure those type r dual voice coil subs are the 2 ohm ones then you series the voice coils on each sub and paralel wire each speaker this will put you at a 2 ohm load
Old Jul 5, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
yeah what he said^^^^
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
