glass break sensor question
Old Jul 1, 2004
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
Does anyone have a glass break sensor on their alarms?? How do they work and do they really work?
Old Jul 1, 2004
XxSoVeReiGNxX's Avatar
I have a regular Viper alarm and it's not too sensitive, but the installer told me the force of something breaking a window will be enough to set off the alarm.
Old Jul 1, 2004
Not if they use diamond cutter or something that doesn't cause alot of vibration. But what are the chances of that happening?
Old Jul 1, 2004
Pharoh's Avatar
Bobaganoosh!
I have a "Glass Tampering Sensor/Mic" and it works REALLY well.
If it's set sensitive enough it'll pick up moisture trickeling down any one of your windows and set off warning chirps until it gets pissed and goes off completely..haha
Old Jul 1, 2004
MegaHurtz's Avatar
I've never had one but I believe they work quite well
Old Jul 1, 2004
Can you adjust the sensitivity of them??
Old Jul 1, 2004
tacheon's Avatar
tacheon is on a distinguished road
I got one. It's a microphone that listens for the frequency of glass breaking, not the force of glass breaking. You can adjust the sensitivity of it. You test it by a glass break tester which is a hand held device that makes a high frequency chirp to simulate glass breaking. Also car thieves don't use diamond cutters. They use something else cheaper and quieter which I will not mention on the web for obvious reasons. However, this still makes the high frequency sound to to set off the glass break sensor. I highly recommend these over these stupid shock sensors. A properly adjusted glass break sensor doesn't false.
Old Jul 1, 2004
Gonna have to look into that. The problem now is the rattler I have doesn't have any extra ports so i have to update it first. Need to anyway it sucks
Old Jul 1, 2004
MegaHurtz's Avatar
You could try diode isolating it and put it on the same circuit as your shock sensor if you have one... that would probably work
Take note of how I say probably
Old Jul 1, 2004
I was going to do that with a motion sensor I bought but the shock alarm is internal. It's all one unit. I think thats why I can't get it as sensitive as I want
Old Jul 1, 2004
MegaHurtz's Avatar
ahhhh
Yeah, buy a new alarm brain with the inputs for this kinda stuff
Old Jul 1, 2004
JJF's Avatar
JJF
JJF is an unknown quantity at this point
Your alarm should have an instant trigger wire you should be able to use. It is probably blue.
juror
Jun 9, 2015 02:15 PM
juror
May 26, 2015 06:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
