DIY Amp install
Old Nov 16, 2001
ROBREALZCIVIC's Avatar
ROBREALZCIVIC is an unknown quantity at this point
DIY Amp install
Where can I find a DiY for installing an amp?
Old Nov 16, 2001
IDQcivic's Avatar
IDQcivic should not be trusted
it's really not that hard. Most amps come with instructions. Basically your amp has a power ground remote and speakers. Run the power to your battery using at least 4 gauge and fuse less than a foot from the battery using the amps recommended fuse type. Ground the amp in your trunk. run the remote wire to the back of your head unit and run a set of quality RCA's from the back of the head unit to the amp. Lastly just connect your speakers to the amp making sure to connect positive to positive and negative to negative. it's that easy. When setting your gains turn your head unit to 3/4 then slowly turn your gain up until it distorts, then back off a hair. Later.
Old Nov 16, 2001
VNlilMAN's Avatar
The Standard One
i followed this n was able to install my amp.. if you have any questions just post it here...
http://www.crutchfield.com/infolib/S...s-installation
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
