teach me!!!!!
Old Jun 20, 2004
thom's Avatar
/////ALPINE
teach me!!!!!
can someone teach/show me how to install component speakers?
especially installing tweeters.
with pics step by step.
this will be a good DIY.
Old Jun 20, 2004
Tweeters are fairly easy. Just run the wires and mount them. Door panel needs to come off, and I did a DIY for that already. I have mine wired to the deck power with the speakers on a separate amp. So I just ran wire from the deck to the sail panels above the door. The infinity tweets I got came with surface mount hardware. Just had to drill a hole and put em in.
Old Jun 20, 2004
alex053's Avatar
where do you want to mount them so that we can tell you how to do it?
Old Jun 21, 2004
thom's Avatar
/////ALPINE
next to the door open thing. like this
http://www.7thgencivic.com/memberrid...cat/all/page/1
Old Jun 21, 2004
doubledeuce2k2's Avatar
use a hole saw and a dremel. and do it right the first time. i surface mounted mine, flush may be a little tougher. measure the center where you want them to go, mark it with a pencil, put the hole saw to it and then sand to enlarge the hole as needed. not that tough to make a hole
Old Jun 21, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
I'll try to show you the whole process when I do the other door on thursday. It's a bit of a challenge, but I had a great time doing it.
My question for others who have installed components is where do you guys mount the crossovers?
Old Jun 21, 2004
brash's Avatar
brash is an unknown quantity at this point
I stuck my crossovers inside the door between the panel and the plastic sheet (so they wouldn't get wet). They just fit between the big foam block and one of those plastic clips. I have to wiggle it a bit to get it in right when I pop the door panel on, but since I'm not making it a habit of popping it on and off, that's not really a problem... You might have a different sized crossover, though (mine was for JL VRs).
Also, I installed my tweeters on the sail panel, surface mounted, and that was a piece of cake (and looks pretty good IMHO). In fact, I don't know that I'd bother going to all that trouble to mount the tweeters next to the door handle. If I were going to flush mount them -- or put them on the door panel at all --, I'd at least put them in a good (SQ-wise) position (i.e. near the woofer). But I'm definitely a function-over-form guy. (The reason they are on the sail panel, if anyone is interested, is because the sail panel is cheap to replace, as opposed to the door panel, and I'm leasing my car...)
Old Jun 22, 2004
i put my crossovers inside the rear seat. they were big suckers, and i didn't want to deal with possible water in the doors.
smoke4
Jul 3, 2003 06:31 PM
sKwiD
Feb 3, 2003 01:12 PM
