Radio Help Needed!
Old Jun 17, 2004
supernootz's Avatar
supernootz is a jewel in the roughsupernootz is a jewel in the roughsupernootz is a jewel in the rough
Radio Help Needed!
Ok, I've had a Sony HU in my civic for over 2 years. Suddenly, out of nowhere, the FM radio reception ***** the bed. Nothing. AM radio works, as does the CD Player. Everything else is normal.
I was always a bit skeptical of the no antenna thing. Did something go wrong with the HU or is there a weak link in these antenna systems I should check, for example, a plug perhaps that came undone?
Any advice appreciated.
Old Jun 17, 2004
doubledeuce2k2's Avatar
i would check the plug. it looks kinda like a headphone plug in the back.
Old Jun 17, 2004
supernootz's Avatar
Alright, I'm stupid as all hell with this stuff. How the *%#@ do you remove the radio from the dash?!?
Old Jun 17, 2004
supernootz's Avatar
Goddamn It Somebody ****ing Help Me!!! I Can't Get The ****ing Head Unit Out!!!!
Old Jun 17, 2004
zen_master's Avatar
damn....doood...
getting out of that HU takes time...
i recommend for you to look at the DIY section...
Old Jun 17, 2004
supernootz's Avatar
I completely ****ed up my **** now. The manual says to use a little screwdriver, push a tab on each side and pull it out. Well goddamn it didn't work and I totally mangled the thin metal and screwed up the plastic around my dash. WTF am I doing wrong, the goddamn thing won't come out!!
The DIY is for removing a factory radio. I'm trying to take out a Sony Piece of **** XPLOD.
Old Jun 17, 2004
zen_master's Avatar
relax dude....
if u don't relax, ur gonna brake ur car even more...
u need the DIY to take out the panel.....and then, you can easily access the antenna cable! =)
Old Jun 17, 2004
supernootz's Avatar
First Zen, thank you for your replies. Apparently, I'm a ****ing retard. This should be simple. Why do the Sony instructions say nothing about taking the dash apart. It's supposed to pull the hell out and doesn't.
Old Jun 17, 2004
fonto's Avatar
The LA Clipper
Before you take the time to take the radio out, since you are not sure how to do it, you should check the other two antenna connections.
There are three places where there are antenna connections. One by the back window on the left hand side (as you face the rear) in the upper back window pillar.
The second place is in the c-pillar (aka the kick panel). This is by your feet on the passengers side.
...and the third is ofcouse is behind the radio.
I would check the first two first because they are easy to get to. Just make sure that they are connected properly.
Old Jun 17, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
because the sony instructions are for the mounting chassis that the radio sits in, however thats not going to work in our cars because there are screws that go through the side of the radio that hold it to the dashboard panel, and the only way to remove it is by following the DIY and removing that panel.
Old Jun 18, 2004
zen_master's Avatar
exactly, u gotta take the panel out in order to get access to the wiring harness...including the antenna..
Old Jun 18, 2004
supernootz's Avatar
Okay, thanks to you three for helping! I'll try again today and let you know how it goes.
Old Jun 18, 2004
supernootz's Avatar
Update: Well I got it out, but not the way I was supposed to. I just couldn't figure out how to get the dash piece out with the A/C Controls, etc. Somehow I ended up busting it out, I guess it wasn't installed properly the first time.
The connection behind the radio was fine, the one at the rear by the window was fine, I couldn't locate the one by the passenger's feet, though.
Anyway, I put a different radio in and it works fine. I guess the FM receiver blew out on my old radio.
Everything's cool now, I really want to extend my gratitude to you all that helped me out.
Old Jun 18, 2004
zen_master's Avatar
awesome!
no problem man....
so, did you succesfully put everthing back into it's place?
Old Jun 18, 2004
supernootz's Avatar
I did, or at least, I think I did. All I know is that everything works the way it should and everything appears good from the passenger cabin. The radio seems stable within its confines, even though I didn't use any screws to secure it. What I did was (and I have no idea if this is correct or not) bent a bunch of those tabs on the thin rectangular metal plate. When I slid it in, it seemed to 'lock' in place and brace itself. Hopefully it holds up. Out of curiousity, where exactly is the antenna connection by the passenger's feet? I couldn't locate it.
Old Jun 18, 2004
glad you got it worked out OK. i busted all those clips at one time or another, just makes it easy to change stuff around later, they really aren't that neccesary
paddystrang
May 18, 2015 09:56 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Myredjonda
Apr 14, 2015 07:00 PM
