Sail panel removal
Old Jun 14, 2004
MegaHurtz's Avatar
Sail panel removal
How do I remove the sail panel? Just pull it off?
Where did the door panel removal DIY go, I'd like to see it... I hate this new site, all the good content was lost
Old Jun 14, 2004
brash's Avatar
brash is an unknown quantity at this point
Yup, just yank!
Door panel removal for a sedan (don't know if you have a sedan or not, but it is probably similar for a coupe). (EDIT: It is also for a 2004 EX, in case that matters).
- yank off the sail panel.
- Behind the door handle is a small panel with a little slot at the top. Insert a small (1/8" or smaller), flat screwdriver into the slot, press down, and pull toward you. The panel should come off easily (as in, no damage).
- Behind the panel are two screws you need to unscrew.
- In the door handle itself are two screws, too. To get to them, you need to yank off lower part of the handle. Not sure how best to describe the process... just try pulling a bit in different places until you get it off.
That's it. Remember to pull out the plug for the electric window(s) and lock(s) if you have electric. And don't twist/pull the door handle too much to get it through the slot. I somehow busted up my lock a bit, so it doesn't lock/unlock correctly unless the door is closed (which, luckily, is when I want to lock and unlock it). You can actually take off the handle from the little metal pole by unsnapping a small plastic piece from the metal. Then the handle will slide right off.
Have fun.
Old Jun 15, 2004
MegaHurtz's Avatar
Thanks
Do I have to remove the part of the armrest that contains the power window and lock controls? Any other hidden screws?
Old Jun 16, 2004
doubledeuce2k2's Avatar
not exactly. you remove the bottom half of the armrest, there are 2 screws deep inside the holes you remove (not the surface ones). there are only 4 screws total to take off
theteju
Aug 5, 2015 06:59 PM
Roman Rembacz
Jul 16, 2015 12:30 PM
orangeju1ce
Jul 14, 2015 08:32 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
