subs go zzzzz
Old Jun 2, 2004
TWiSTEDKAOz's Avatar
TWiSTEDKAOz is an unknown quantity at this point
Angry subs go zzzzz
well one day i got bored so i went an opened up some new subs, i hooked 1 12'' infinity 12.1d to my stereo... ( that jvc with 460watt power ) and like i was testing the sub... and its goes " ZZZZZTTTT " its like something is hitting it, but i checked an nothin hitting it.. so what does that mean??
Old Jun 2, 2004
MegaHurtz's Avatar
Check to make sure the tinsel leads aren't hitting it when it is playing
Old Jun 3, 2004
and if they are??.. what i do..?
Old Jun 5, 2004
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Try and very slightly bend em outward. I had a similar problem with 6x9's a few years back. SO ANNOYING!!
Hope this helped.
Old Jun 5, 2004
WhiteRabbit's Avatar
could be a dustcap coming loose and buzzing, too.
are you hooking up a car subwoofer in a home environment?
Old Jun 5, 2004
yeah it was connected to my stereo... i only did that to check it to make sure it works cuz i bought it off ebay...
Old Jun 6, 2004
id expect the buzzing at high excursion, then.
not a guarantee of it doing that in the car.
maybe, but not neccesarily.
Old Jun 6, 2004
thom's Avatar
/////ALPINE
do you have a sub box?
if it is, your probally leaking air.
to stop that, add some poly-fill stuffing in it to stop the air flow.
+ your subs will sound alot better.
http://www.crutchfield.com/S-SP8XB97...&avf=N&search=
Old Jun 6, 2004
polyfill doesnt help a leaky box.
9 times out of 10 a leaky box is caused by air leaking from around the woofer. my favorite fix for that is gorilla snot (strip caulk), weatherstripping works in a pinch as well.
the other time a leaky box is caused by poor construction, and jsut needs a bead of silicone around all the edges to fix.
good call though, if the buzzing noise isnt being emitted from teh subwoofer itself, not coming from behind the dust cap, then its definitely posiible its a leaky box
Old Jun 6, 2004
nawh.. its not even in a box yet... i just took it out of the box an got some speaker wires at radioshack an then hooked the sub up to my stereo..
Old Jun 6, 2004
MegaHurtz's Avatar
Where is it mounted then?
You need a box, it might cause a rattle if its not in a box
It is not good to run it off deck power either
Old Jun 6, 2004
not in a box...in a home....powered by a home theater amp...
yep, i think we found the source of the buzzing!
your woofer is fine.
Old Jun 7, 2004
its mounted nowhere.... its on top of the box...lol... but yeah if you guys say thats the problem then ill try to get a box for it and then see wassup... thanks..
Old Jun 7, 2004
Sim012's Avatar
Sim012 is an unknown quantity at this point
might have burned a voice coil..
Old Jun 8, 2004
hmm...ill try to check it out..
Old Jun 12, 2004
well does anybody else have any other suggestions tho?
Old Jun 12, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
if you are still running them free air then get a damn box...i'm sure the sub will make nasty rattling sounds if run free air...
Old Jun 12, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
polyfill only makes a smaller box seem bigger, and use PL-400 floor adhesive to seal the joints when you build a box,,,,,,that shi is like steal when it sets.
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
sf3r8z
Sep 23, 2015 03:26 PM
redcloud
Sep 7, 2015 01:45 PM
