Power wire through firewall
Old Jun 2, 2004
werm's Avatar
werm is an unknown quantity at this point
Hey I havent took anything apart yet but where do you guys run the power line though? What's the best spot? I'll be using 4g wire also. Probably behind tyhe glovebox or something... right?
Old Jun 2, 2004
02 silver si's Avatar
02 silver si is an unknown quantity at this point
I know for the EP's people run them through the hole for the fog lights.
Old Jun 2, 2004
brash's Avatar
brash is an unknown quantity at this point
I searched this forum (hint hint) and found that people seem to run them under the glove compartment, off to the left a bit. So that's how I did it. Had to poke a hole in the rubber first, using a coat hanger.
Old Jun 2, 2004
MegaHurtz's Avatar
Below the glove box to the left, there is a cluster of wires going thru a rubber grommet. You can run your wire thru there. It was a pain with 4 gauge, but fairly easy with 8.
Old Jun 2, 2004
civic01vtec's Avatar
i ran 0 gauge though there, plus the wires for my fuel system, boost gauge and a/f gauge.
Old Jun 2, 2004
EnProceso's Avatar
am i the only one who ran them throuh the firewall on the divers' side?
Old Jun 2, 2004
MegaHurtz's Avatar
Looks like it
Where abouts did you get it through over there?
Old Jun 3, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I ran mine through on the drivers side (through where the clutch goes (I hava an automatic). I had to add a gromit. I have a hybrid and the battery is on the drivers side.
Old Jun 3, 2004
up4surf's Avatar
up4surf is an unknown quantity at this point
I ran my cable between the passanger side fender and engine compartment to the door jam. From there you will see a grommit that you can cut a hole big enought to run 0/1 ga. (what I ran). doesn't interfear with the door or hinges at all.
Old Jun 3, 2004
alex053's Avatar
i drilled a hole on the passenger side near the cluster of wires....used a gromet and ran the 0 guage thru there..most people run it down the passenger side cause the battery is on that side.
Old Aug 1, 2004
wonderz's Avatar
wonderz is on a distinguished road
Question:: Is the firewall on the passenger side is the hole on the left side (of passenger) floor?
'cause if it is... how did you guys put wires thru it? it looks pretty packed... and even when i try to poke a screw driver in, still couldn't get it thru....
TIA
Old Aug 1, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Use a wire hanger with the power cable attached to one end. It's a tight fit but it will go through. People have 0 gauge wire going through that hole.
Old Aug 2, 2004
MegaHurtz's Avatar
There is space to the right of the cluster of wires that you can push a large wire through
Try the wire hanger way. The end will give you some poking power, and it keep the wire stiff so it doesnt bend when you try and apply force to it
Old Aug 2, 2004
LudlamTheory's Avatar
i boogie for the raindrops
i have 0 gauge, 2 10 gauge wires, and 2 or 3 16 gauge wires
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Dmitri
123
Oct 13, 2005 08:01 PM
02CarbonCivic
Jan 7, 2002 02:36 PM
mikalem
Jan 5, 2002 10:21 AM
Mary
Jan 2, 2002 06:42 AM
