Do I need a capacitor?
Old May 22, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
Question Do I need a capacitor?
Hey sup guys, I have a question if I need a power capacitor.
This is what I have:
2 12" 1200 watts sony xplod
2 1200 watts amps sony xplod
any suggestions will be appreciated thanks...
Old May 22, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
If your lights dim and it bothers you, get one. All they do is help reduce/stop dimming.
Old May 22, 2004
Yup, it's just a coverup for the real problem--not enough power to run your amps. You need a bigger alternator to really fix the problem.
Old May 22, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
What type of alternator would you reccomend ? Will having too big of a alternator damage the electrical system ?
Old May 22, 2004
Possibly. Alot of stuff on the car isn't rated above 15-16 volts. So you have to be careful which one you get. One option is rewinding your old alternator to produce more power, but that could be costly. There are threads that talk about different alternator types.
Old May 22, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
u have a sony it wont work long enough to warrent 1. naa im just kiddin. u might wanna invest in 1 but u dont "NEED" it your car will provied enough power. but if u add another amp id get 1.
Old May 23, 2004
Mystic3030's Avatar
Higher power alternators don't put out more volts, they put out more amperage. They won't damage the car unless you get one thats not made for the car and dont fabricate it in correctly.
Replacing the stock battery will also help to remedy the problem. I would not suggest investing in a new alternator till you do a serious system...your amp will probably never exceed 400 watts of RMS power.
Old May 23, 2004
maxxam25's Avatar
cool thanks guys for the advices...
Old May 23, 2004
WhiteRabbit's Avatar
http://www.betteraudio.com/geolemon/newmain/battcapalt/
hopefully this'll save some people some money, some ideas, some creativity, and some headaches
nguyen949
Oct 2, 2003 02:26 AM
kalipnoi
Aug 31, 2003 12:45 AM
jkim1978
Aug 29, 2003 09:17 PM
Civic2001LX
Apr 27, 2003 11:42 PM
noahnoah
24
Jul 21, 2002 06:47 AM
