need help
Old May 18, 2004
EternalBluePearl's Avatar
EternalBluePearl is an unknown quantity at this point
need help
my front speaker keeps loosing sound from time to time it start this w/e
is crossover will help my system
this thing is annoying
my system
infinity comp system in front
infinity coax in rear
(2) no name amp
(1) jl audio sub
sony HU
Old May 18, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
my system
(2) no name amp
(1) jl audio sub
sony HU
I kind of had a little difficulty deciphering the post, one because I don't know what w/e means. But, let me fervor a guess, and see if I understood or not: Your front speaker periodically quits playing, it started this weekend. You want to know if a crossover would help?
If that is correct, did not a crossover come with the component set? Is everything hookde up right? Did you connect by crimping, or did you connect with solder and heat shrink tube? Are any wires shorting out by having naked places on them touching body panels when you hit a bump? When does it happen most often, when you hit a bump, during normal driving conditions, only in the rain/wet weather, etc? Please be more specific in describing the problem so it'll be easier for everyone to address. (I'm not being an ***, I'm just trying to figure out what may be causing the problem, and was wondering if there was more information available.)
Old May 19, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Loose connection ....
Old May 19, 2004
yap i lost power i guess only in front and yes it comes with crossover already
i lost power for 1-2 minutes then will come back again then for 5 mins it will go off again...we dont have a nice road in here so everywhere u go there a bump
i have it installed by a professional for almost 2 years...dont know how they install it
never open the door panel again since
Old May 20, 2004
Check your connections. And check for naked spots in the wire causing it to short out.
Old May 20, 2004
ok thanks
the tweeter has power and the woofer dont have power
i stick my ear on both doors
Old May 21, 2004
catalin's Avatar
catalin is an unknown quantity at this point
The best thing for you to do is take it back to the installer that originally did the job. Since you paid someone for it you should have some sort of guarantee. Most people will guarantee ther work for life.
