buying a new amp
Old May 5, 2004
SMBFC's Avatar
SMBFC is an unknown quantity at this point
buying a new amp
I Need an amp that will do 400 watts to both (2) 12" woofers RMS.
What am I looking for when I shop around?
my last amp was a free one, so I did not have to do any searching other than for the manual.
Old May 5, 2004
alex053's Avatar
is that at 4 ohm??
just shop for a name brand amp that will do 800 watts rms into whatever load your speakers present. Rockford Fosgate 801S would do the trick..check ebay.
Old May 5, 2004
SMBFC's Avatar
yea here are the specs of 1 woofer
Power Handling: 400 watts RMS
Dual 4 Ohm
2 or 8 Ohm Operation
Old May 5, 2004
WhiteRabbit's Avatar
yeah, any 700-900 watt amplifier that does power into 4 or 1 ohm.
class D amplifiers are usually 1 ohm stable. 2 channels that can be bridged are usually 4 ohm stable only, but will still work perfectly for you.
earthquake makes a 700 watt 2 channel amplifier, and a 1000 watt class D amplifier.
ARC makes a 4 ohm stable class D amplifier that does 900 rms.
take a look around, there are tons of amplifiers out there for you!
Civic65
Jul 19, 2015 10:13 AM
srtlat
Jul 17, 2015 11:53 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
