Prob with sub.
Old May 3, 2004
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Prob with sub.
Ok, guys/gurls ...when I turn my car on my cd player powers up, then u hear a bump from my sub. you look in the trunk and the sub isn't flat across, It is extended upwards.When I turn the car off the sub goes where it is supose to go., How do I remedy that?
Old May 3, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Im a little confused when you say it isn't flat across and it is extended upwards
Old May 3, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
are u saying that the sub is extended towards you when u turn on your HU?
if so, that could mean that your sub is blown...hook up a multi-meter and check how many ohms you're reading from your sub...hopefully it's reading the correct ohms the sub should be putting out.
Old May 3, 2004
ZSKCivic01's Avatar
Extreme Member
yea, im thinking that your talking about the sub extending outwards to its X-Max or whatever. For example, when I tested my sub one time just to make sure it wasn't blown, I connected the voice coil to a regular battery and the cone goes out and stays there.
Old May 4, 2004
Marcus's Avatar
Yeah, it's Exte3nded to the X-max. I'm taking my car to get hooked up properly..heheh Not that I can't do it it's just I always have problems with stereo systems
Old May 4, 2004
Marcus's Avatar
oph yeha, the sub is mounted in my trunk..Like WHere the spear tire would be. But Flat across, so the type R letters are facing directly up in the trunk.
Old May 4, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
sounds like its hooked straight to the battery, (lol, no amp at all)
Old May 5, 2004
Marcus's Avatar
Well today I will get it stightend out. Thanks anyways
Ma213802
May 18, 2015 07:01 AM
JackTripper
22
Jun 6, 2002 09:14 PM
DogstyleEX
Suspension
Apr 20, 2002 02:47 PM
Daniel420
Mar 26, 2002 07:26 PM
sorphin
Feb 22, 2002 11:35 PM
